Question about ASUS PCI-L3C920 Network Adapter
Ethernet controller with big yellow question mark
How do i fix this ethernet controller of asus cuv4x-m, when i check the device manager i find a big question mark on ethernet controller, i dont have internet
connection, this i notice when i finish fixing my os after i encounter a virus in my computer
  • ASUS Master
  • 6,487 Answers
You need to reinstall the software for that, if its a ethernet card built in to your motherboard you can find the software for it from the motherboard setup CD , and if its a additional device to your computer just run the setup CD for it to reinstall the software back....
Posted on Nov 07, 2008
Asus 1001p how do i get usb port to work? i'm trying to hook cable modem to comp thru the usb
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
May 07, 2011 | ASUS Computers & Internet
My ASUS M2N SLI onboard LAN connection is not working, I do not have an Ethernet Controller in device manager, and there is no drivers that i can find online to solve this issue. I just re installed...
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-
hope this helps
Mar 22, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus K8u-x, please i need ethernet controller. for my driver give me a link..... im waiting
the driver should be on the disk supplied by your isp internet service supplier
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click update driver also will be the options to disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Jan 09, 2011 | ASUS K8U-X Motherboard
Ethernet controller misssing
I assume your referring to the driver. You can get that HERE.
Thanks for asking FixYa.
Mark
Mar 02, 2010 | ASUS P5V800-MX Motherboard
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
I had to reformat my laptop and now I cannot get ethernet to work
you need the drivers for those devices marked with yellow --"yellow"ethernet
controller will not allow to access the web to download drivers to solve your problem--options are:- use the "original" driver disk that came with the laptop or download to another pc/laptop and transfer drivers using usb key.
Apr 27, 2009 | Dell Inspiron E1505 Notebook
ASUS CUV4X-C ethernet adapter not found
i have format my computer and now other devices in computer are demanding software namely Audio Device on High Definition Audio Bus,Ethernet controller,SM Bus controller and Video controller(VGAcompatible)
Jul 31, 2008 | Intel Motherboard
Ethernet controller for asus p5pe vm
i have also a problem about ethernet controller, i can't access my internet connection !
May 04, 2008 | ASUS P5PE-VM Motherboard
Motherboard Problem
you need to run the cd that came with the motherboard...
Jan 06, 2008 | ASUS P4VP-MX Motherboard
Computers & Internet Logo
2,477 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
