Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Whirlpool ED5VHGXML15 dripping onto hot spot in freezer
I have a side-by-side Whirlpool ED5VHGXML15 fridge/freezer. I started hearing a strange noise and after investigating I found water dripping onto a metal plate at the back-bottom of the freezer. The metal plate was hot so the water sizzled when it touched it. There doesn't appear to be a leak external to the fridge and the temperature inside the fridge and freezer are fine, but this seems a bit odd and potentially dangerous. Why is this happening and what can I do?
  • lbenge Nov 20, 2008
    kenmore top freezer 5 years old hot around outside of freezer started in one spot by the handle now its hot or warm to touch all the way around water dripping inside fridge probably going to buy a new one there goes christmas presents for wife and grand kids.i think this fridge should have lasted much longer since it cost about 900 dollers.
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: The freezer on the inside
this is the defrost cycle and is nothing ot worry about. the unit has a heater that comes on about every 8-12 hours to melt accumulated frost from the evap coils. this heater is alot like the coils on yous stove. it should stop heating within 30 mins and resume cooling shortly afte that. thx peyton
Posted on Feb 02, 2009
  • 1462 Answers
SOURCE: sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Posted on Sep 25, 2008
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
I have a Kenmore side by side that is not cooling the way it was yesterday. The fan & compressor are working but its not blowing the cold air into the fridge or freezer. In the freezer, I hear as the...
It sounds like you are refering to the defrost cycle. This would make the noise you hear. Try cleaning the condensor coils and the fan that is in the bottom where the compressor is. This may help. let me know. have a great day.
Apr 27, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Hi. You answered a question about a "sizzle" noise coming from the freezer of a GE Profile side-by-side. Your answer was "The sizzling in your case means that it is working....it is just...
the defrost cycle happens 1-2 times in 24 hours usually, and lasts 20-30 minutes.at which time the cooling process starts again.you may or may not hear the sizzle during the 20-30 minutes.if the frezer-freezes and the fresh food section is cold enough its probably o.k.
Mar 28, 2011 | Refrigerators
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
Dec 21, 2008 | Whirlpool ED2FHSS Side by Side...
Sound of water dripping on something hot
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
