Question about Canon ES60 Hi-8 Analog Camcorder
No image in viewer
My cat knocked it over and now I can't see anything through the viewer. If I connected to a TV I can see it's recording fine. If I move the viewer I can sometimes see what I'm recording but then if it moves I lose it again. I'm assuming I'll need to get it fixed however, would like an idea of how much it should cost and what part I would need. I went to one repair shop and the guy told me it would cost over $200.00 and I would have to send it away. Help!
  • ginjabrd Feb 13, 2008
    A couple of years ago my brother dropped my Canon ES60 Hi-8 Analog Camcorder. Afterward I couldn't see an image in the viewfinder. I just figured that I was S.O.L. and put it up. About 4 yrs. later I just started messing around with it and it worked. I had no problems with it for about a year until last week when it happened again. To best of my knowledge it was not dropped this time. There is no image in the viewfinder, however when it is hooked up to the T.V. you can see that it is recording and playsback just fine. I was hoping that someone might be able to help me solve this problem with having to take it somewhere. Any suggestions would be greatly appreciated.
    President:
  • 3,130 Answers
You never know what it will cost till you take it apart and most peeps do send them to the manufacturer so cut out the middle man thats gonna add on a shipping and handling fee + who knows what else. Call canon at 1 800 828-4040 good Luck.
Posted on May 02, 2006
There is a small circuit board located in the adjustable viewfinder. A 4 pin connector with a small ribbon cord is plugged into this circuit board. Your problem is that after many hours of adjusting the view the circuit board ribbon connector has come loose for the board or one of the 4 surface mount connectors are loose.
Posted on Nov 07, 2010
  • gwjerry Feb 11, 2015
    There is a small circuit board located in the adjustable viewfinder. A 4 pin connector with a small ribbon cord is plugged into this circuit board. Your problem is that after many hours of adjusting the view the circuit board ribbon connector has come loose from the board or one of the 4 surface mount connectors are loose.
I have a big toshiba cinemas series tv which is connected to a VCR Plus with cable channel changer - VHS model# M672C - 4 Head Hi-Fi Stereo, but I would like to have that VCR connected to another TV which...
You don't say what kind of connections between the items are, but I know you can use a "Scart Switching Box" if you have scarts, to record from one thing to another. I don't know if it will be any good but you can look into it. Found on Amazon by the way, image below:
Aug 20, 2011 | Televison & Video
No image on the viewer; no image being recorded.
If your Canon A80 camera shows previously stored images of memory card in playback mode but does not show live view in camera mode to take fresh picture then ccd imager chip got defective and need to be replaced.
Local camera repair shop will help you to replace ccd imager chip because camera will take apart in detail and soldering work is needed.
Thanks.
Jul 14, 2010 | Canon PowerShot A80 Digital Camera
Symphonic sc 1304 combo vcr records double images
I would try to clean the heads. Before I do anything else. You can buy a good head cleaner at Wal-Mart! Good luck with this.
Mar 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Blue screen
the video ribbon is probably not secure in its connector and as you open the door it is pulled from the simple housing it connects to these cameras are absolutely terrible the lcd screens will always fail because of a design defect in the ribbon and its routing and fastening.Inside the lcd screen to secure it they use electrical tape as a fastener so ridiculous.
Aug 08, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Capturing a video from the console
It's not a problem, it's designed that way. Its called Macrmedia Encryption. It's so you can't record commercial DVD's onto other media (anti-piracy). Since the game is DVD based, it will not be recordable.
Sep 17, 2007 | Sony PlayStation 2 (PS2) Console
Canon ES60 Hi-8 Analog Camcorder Logo
171 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
