Question about RCA RCR460 Remote Control
Rca rcr460 remote control programming
Rca navilight remote control, 4 device controller
  • 5 more comments
  • Anonymous Sep 14, 2008
    PROGRAMMING SOLUTION: press and hold the device key you want to program, then press the on/off button, hold the two buttons until the lights stay on. release the buttons, press the play button and wait 5 seconds while the codes automatically cycle through. After 5 seconds press play again so that the next cycle can take place. continue to press play within 5 second intervals until the device turns off. once it turns off press the release button twice, then press stop. press the power button to turn the device back on. once you have cycled through the remote by pressing play 20 times the remote lights will flash, this is an indication that the remote will not controll that device.
  • Anonymous Sep 27, 2008
    FUSTRATED TRYING TO PROGRAM THE DAMN REMOTE CONTROL RCR460
  • Anonymous Nov 09, 2008
    i do not have a release button on my remote
  • ron1824 Nov 24, 2008
    the remote does not want to work with codes givin
  • Bill Poffenberger Apr 03, 2009
    RCR460 won't speak to Sylvania.
  • Anonymous Apr 07, 2009
    what is the the release button?
  • gordita1910
    gordita1910 Jun 11, 2014
    i try but i can,t program my tv
Rca rcr460 will control dishpvr
Posted on Sep 19, 2008
To program the navilight 4 device remote rcr460, press and hold the device button you want to program, while holding, press the on/off button, hold both until the lights stay on. release. press the play button once and allow the codes to auto cycle, press the play button every 5 seconds to go on the the next set of codes. once the device turns off press the release button twice, then press the stop button. press power to turn the device back on. once you have pressed the play button 20 times the remote will flash, this means the remote will not program that device. I hope I did not miss any steps here, I am doing this from recall.
Posted on Sep 14, 2008
Need to find out how to program sylvania tv!!!!!!! and steps
Posted on Sep 12, 2008
I need the code for an Insignia TV, so I may program my RCA remote.
Try 1020 for an Insignia TV. Most RCA universal remote codes can be found at http://www.rcaaudiovideo.com/remotecodefinder/ . Use the drop-down menus to select your remote and then the type of device that you want to have the remote control.
Please note that the codes in an universal remote control are usually limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a newer remote.
I hope this helps.
Jun 24, 2011 | RCA RCR460 Remote Control
Need the codes to set up theRCA RCR660 NaviLight Remote Control
Go to this website they will give you instructions and the code list is 3/4 of the way down in a link. http://voxrightnow.custhelp.com/app/answers/detail/a_id/7742/~/programming-the-rca-rcr660-universal-remote-control-navilight6
Dec 30, 2010 | RCA RCR660 Remote Control
Lost manual need to know how to program rca rcr460
http://audiovox2.info/docs/common/RCR460/RCR460_OM.pdf
Nov 27, 2010 | RCA RCR460 Remote Control
RCR460 Remote Control: I need to know how to program my rcr 461 to my tv....
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  1. Turn on the device you wish to control.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed(VCR,TV)
Make name(toshiba,sony)
Thanx
May 16, 2010 | RCA RCR460 Remote Control
Cinevision DVD player work with RCA universal remote?
You dont have codes for cinevision DVD player.So it cannot be programmed with Codes.
You can try programming withot code
Please follow the below steps.If it dont work then your cinevision DVD player donnot support RCR460 remote.
Code Search:
Thanx
May 07, 2010 | RCA RCR460 Remote Control
How to program an RCR460 remote
i have this remote and to enter the code manually you hold down the mode button (tv vcr etc) and while holding it in enter the code for the device. if the light for that device blinks and stays on then it accepted it. if all lights go off it didnt.
Jun 30, 2009 | RCA RCR460 Remote Control
I NEED OPERATING INSTRUCTIONS FOR RCA RCR460 4-Device Navilight Remote Control.
Download your manual -->here<--
please take the time to give this solution a fix ya rating
clarkco
Feb 20, 2009 | RCA RCR460 Remote Control
I need a 4 digit code to work with rca universal remo
1213, 1122, 1123, 1141, 1321, 1434, 1343,
1342, 1123, 1124, 1143, 1114, 1244, 0018,
0019, 0029, 0038, 0047, 0090, 0135, 0174, 0278
Nov 18, 2008 | RCA RCR460 Remote Control
Rcr460
Here is the site for remote codes:
www.remotecodelist.com/remotes/
Hope ya fix it!
Jan 03, 2008 | RCA RCR460 Remote Control
RCA RCR460 Remote Control Logo
1,314 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
