Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Smeg single fan oven
When i try and switch oven on the light to say the oven is heating does not come on and it does not get hot. Fan and internal light do come on so suggests there is electric supply. Could it be a thermostat or heating element problem
  • 4 more comments
  • Anonymous Jan 02, 2008
    When I turn the oven control to all round heating, the fan works but the oven does not heat up. All other controls work fine. It is a SMEG D04SS-5
  • Anonymous May 31, 2008
    top oven doesn't heat @ all but the control light comes on, self cleaning doesn't work either. bottom oven comes on & heats very slowly but does not seem to keep up w/ the temperature,self cleaning also doesn't work but convetion does work on the bottom, possible the fan works on top but don'T remember. the oven model # IS GLEB27T8ASA,SERIEL NO IS NF22914964.
  • taffy2 Aug 12, 2008
    On my NEFF B1451 oven the thermostat got mechanically damaged and the oven was overheating. Have replaced the thermostat,but now the oven will not heat up at all, main fan does not work and oven light not on. However when I operate main switch with door open the light comes on momentarily and the main fan turns briefly if fan selected on the selector switch. It seems like a relay is cutting off the power to them as soon as it is switched on. Have also noticed current of air coming out of front top of oven whilst heater fan not working, is there another fan ?
  • sheldonb Dec 14, 2008
    i seem to have the same problem, the griller works, but not the oven.tried to locate the reset switch but unable to locate it.
  • Anonymous Mar 21, 2014
    simpson wall oven has no heat the fan still works as does the top element but the oven doesn't get hot
  • Anonymous Mar 26, 2014
    using the fan oven for an extended period the front knobs get hot then the oven cuts off clock goes off etc
We had a similar problem with Smeg fan forced over. The fan turned but the element around the fan didn't heat. Tried looking for the high-limit switch to reset, but couldn't find it. Eventually unscrewed a metal plate off the back of the oven and found a broken wire. Fixed this and the element now works. Don't forget to unplug oven before unscrewing things.
Posted on Jul 18, 2008
    Problem Solver:
  • 6 Answers
Do the top and bottom elements come on when selected?
If the fan comes on, but none of the other elements come on when selected, it might be that the thermostat switch needs to be reset.
By the thermostat connection at the back, there should be a switch - a small blue button, than might have popped out. Push it back in and see if it works...
It worked for me when I replaced my element many years ago, and last night when my oven stopped giving heat, I had to open up the back and reset the button.
Hope it helps
Posted on Jan 24, 2008
Your problem may be an accumulation of 2 or 3 things. no light could be blown bulb or loose connection also you may have a thermostat issue or corroded connection going to element or a blown element. check power at element if power there then element is blown. if no power then check voltage goin into thermostat. it has to be one or the other. KEN
Posted on Aug 20, 2007
Jgish has the answer!! He just saved me $65 or more so many many thanks to him!!
Posted on Feb 17, 2007
  • 641 Answers
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
Posted on May 02, 2006
  • Dov Dror May 02, 2006
    If Fan and internal light do come on, it couldn't be a problem of the main switch or house circuit breaker !!!!!
    Scholar:
  • 146 Answers
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
Posted on Dec 24, 2007
I have the same problem. The oven was working fine until I cleaned it. There was a power failure during the cleaning, but it appeared to function properly until the cleaning cycle finished. I spoke to Dacor customer service and they told me there is a "high limit" switch to ensure that high temperatures do not damage the electronics. They recommended calling a local servicer to come and check the oven and reset the switch. They indicated that the servicer may be willing to tell me over the phone where the switch is so that I could reset it myself. They like to have someone come out just to make sure nothing else is wrong with the oven. Given that there was a power failure in my case, chances are a simple reset will do the trick. You may have a similar situation. If anyone knows where the switch is, it would be good to share on this forum. In any event, I'll call the local service department tomorrow and try to find out.
Posted on Oct 31, 2006
  • Jim Gish Oct 31, 2006
    I figured it out. It was indeed the hi limit switch. To access it, open the oven door and remove the six screws on the black panel above the oven opening. Pull out the black metal shield in the center. Toward the back of the exposed parts in the center is a black round component with a red button in the center. This is the hi limit switch. The red button is the manual reset button. Press this in to reset. Note that it does not press in easily - you really have to press hard until you feel it click. That does the trick.
    President:
  • 3,130 Answers
First thing to check in a case like this is the main switch as this is almost always the problem as if it was just the heating element then the light would come on as well as the fan. Also be sure to check the house curcuit breaker as in this case has been a big amount of service calls for blown breakers Good Luck. Oh yea depending on the ovens type there may also be a control panel that the switch tells the elements and fans and lights to com e on..
  • Larry  Dillon
    Larry Dillon May 03, 2006
    But Dovi you stated first that it could be the heating eleiment an I said if the light wasent comming on then it was a problem with the switch lets get it straight please!??
    LMAO
4 Suggested Answers
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg oven
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg SNZ91MFX1 Fan heating not working
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
4,095 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
