Question about Zenith R49W36 49" Rear Projection HDTV
Color is off....
I seen a question where someone said their color was off and the picture was bowed, and my tv is doing the same thing. A comment left said "i would look for a loose connection around the convergence area". What is the convergence area and where would I find this??
  • james johnson Oct 04, 2008
    the color red is off
The convergence is in the tv its self just about side of the scran if you take off the back of your tv you will see all the wires runing to little bords them are the convergence chips
Posted on Oct 19, 2008
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Model 51S715: 2 issues: (1) Screen is bowed at top...left and right edges turn down and are black. (2) picture color will turn green randomly. If I turn tv off and leave off for a while the color goes...
Ur tv have a problem call convergence,it dying about to be dead.The tv convergence board 2 STK Convergence ICS and some or all it resistors require changing to solved the covergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Rca projection tv is blurry
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Picture conversion
Hi,you have a bad convergence board.Try calling a tv parts house to buy one .They cost about $120.
Jul 22, 2007 | RCA P46924 46" Rear Projection Television
Zenith R49W36 49" Rear Projection HDTV Logo
201 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
