Picture has started to turn pink. Up until a few days ago, color would normalize after 10-15 minutes, now appears to be a permanent feature. Is this an inexpensive fix considering the value of the tv or do I just look to buy a new one? Thanks.
-   our tv has latley started to turn pink aswell! when ever itturns on, its ok for about 2 mins, then the picture keeps changing from normal, to slightly green, to slightly pink, to normal again! when we run it through the VCR, its perfecly normal!! the only thing is, we cant watch sky through the vcr, so we're stuck with the basic 5 channels! -   Guest
Jan 28, 2009
-   The screen of my television set turns to pink.-   uly771
Apr 13, 2008
-   Same exact problem. It started about a week ago and seems to be getting worse. The green color goes out of the set. It has been coming and going but as time goes by it's going more than coming.-   witle
Dec 23, 2007
-   GE 25GT511 When turned on, red line about 1/16" thick shows from left to right in center of screen with a black background until picture comes on. Once picture comes on ( a few secs), it has a pink tink. All color is washed out, faded. Can see faded red lines running left to right (at a slight angle) about 1" apart, from top to bottom of screen. With a B&W movie, it has a slightly pink tint. What is it? Is it worth fixing?-   cbryant011
Is your grey scale or Black and white programming pink?? Thats an indication that the green and blue grids on the picture tube are week or that the red is over driving. First thing is take off the back of the set. Find the end of the picture tube and look at the printed curcuit board there. see if you can find and red drive controls there. Put on a black and white pic and ever so slowly rock that red drive control a little at a time till the picture looks almost normal.. If you get it to be a little \less pink then stop right there but if it starts to get a bit green or blue then try rocking those controls all back and forth till you get the bese B&W picture you can BUT BE VERY CAREFULL as there is alot of voltage on this picture tube and if your not carefull it will bite ya. Now dont be too critical as the tube is a bit weak so you probably wont get a perfact grey scale so if after a while live with it or get a new set. Good Luck.
digastar locked up displays lock.Can't use remote,,or find menu .Can't turn on with start . \nothing...
(More)
digastar locked up displays lock.Can't use remote,,or find menu .Can't turn on with start . \nothing on tv works..
I have a universal remote. I need the codes for a Jensen tv model Q2749J to program remote. Please...
(More)
I have a universal remote. I need the codes for a Jensen tv model Q2749J to program remote. Please help!!
TV Jensen Q2749. It was working fine until I bought a universal remote control that made the TV...
(More)
TV Jensen Q2749. It was working fine until I bought a universal remote control that made the TV unresponsive so I had to unplug the power. After that the image is distorted and the Menu option are all different plus the default language is Korean I think.
Any idea how I can reset the TV back to its normal setup?
Thanks, JD
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
