Question about Conia DVD8500 DVD Player
Conia dvd player problem
Dear Sir/Madame My Conia DVD player (not recorder) has: M550 printed on the front of the unit. The problem I am increasingly experiencing is: Freezing, or sticking when I play orrowed DVDs and 'home burnt' DVDs that have been viewed a number of times and consequently have lots of very fine scratches (yet with no obviously terminal damage). The sticking problem occurs both when playing, as well as when fast-forwarding. The sticking problem can occurr every few seconds making the program impossible to watch, or else it can stop the program altogether. The sticking problem is usually accompanied by an unusual sound which at this stage I will refrain from attempting to describe in case I confuse your prognosis. The sticking problem only rarely occurs when playing DVDs that have been recorded by my family on a separate DVD recording machine, which we presume is becase there are NO scratches on those disks whatsoever. As my Conia DVD is no longer in the warranty period, I would be extremely grateful if you are able to assist me in this matter. I am relatively practical, so would not be afraid to open the unit and check/replace parts if you are able to explain roughly what to do. Kind regards Dale + 61 405 467616
    President:
  • 3,130 Answers
Dale, Have you tryed yet to clean the lens surface on the dvd player yet ?? A small build-up of film or dust can make a cd/dvd player's tracking ability to go downhill quit fast. The lens Im talking about it on the Laser Pick-Up assy. Us an approved cleaning disc to do this or take off the top cover and take a small q-tip with just damped with alcohol. Very carefully clean the surface in a circular motion and let dry then clean again with a dry q-tip to get off anything lefyt on the lens. Now for the disc. Those small scratchs can be gotten rid of with a disc resurfacer. The disc resurfacer will work on very minor and shallow scratchs. you can only get rid of them if you dont see any dark inside the scratch or you can barley feel the scratch with your thumb nail. If the cleaning dosent assist you then the unit will neeed a tracing/focus alighnment and thi is something you cannot do unles you have an alighnment/service manual and the proper equipment-ie scope & alighnment disc's. Good Luck
Posted on May 02, 2006
I have a HD video file to burn to dvd. Need to know What compression function I can use , so I can use to burn and play on the Conia dvd player
Winrar compress it if it is too large to be loaded on a CD. You can compress to parts then extract the parts to he burned on a CD
for the burn cd you can download nero for free
May 07, 2015 | Conia Televison & Video
Remote for the Conia M250 has stopped working. Can we get replacement remotes?
Follow this to order a new one
http://www.conia.com.au/service.html
Jun 07, 2011 | Conia Televison & Video
Dvd stuck in conia clcd1930
To Eject the DVD, my conia clcd1930 needs to be in "DVD" mode. This Mode appears to activate power to the entire DVD module. So the Eject button will only work in this mode.
Feb 19, 2009 | Televison & Video
Any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
Feb 09, 2009 | Conia DVD8500 DVD Player
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
Conia DVD MR910D Recorder. Picture is Black and White
Ok sounds like your settings have been changed some how either on the TV or the DVD unit. Check your settings on the DVD unit. In the menu options. There should be a settings for the picture. If you can't find it there, some newer DVD players are also upgradable from the manufacturers website. You just use you PC to go there, get the latest firmware update. Save it onto a USB stick and plug the USB stick into the unit with the power off. Turn the power back on and it should solve the problem. Or you can also set almost every DVD player to default factory mode. You can find out how to do that for your particular model on their website. ..hope that helps you
Oct 21, 2008 | Conia DVD8500 DVD Player
Dead power supply in conia dvd recorder
Power supy intermitinenly fails
Aug 17, 2008 | Televison & Video
Firmware for conia 160gb dvd recorder
sir try this link! http://www.dtvforum.info/index.php?showtopic=32172&pid=632554&st=40&#entry632554
Apr 06, 2007 | Conia DVD8500 DVD Player
Televison & Video Logo
172 people viewed this question
Top Conia Televison & Video Experts
degroot2940
ray gallant
Are you a Conia Televison and Video Expert? Answer questions, earn points and help others
