Question about Hotpoint NLL113EYWO Electric Dryer
Where do I find the heating element in my hotpoint dryer
Hotpoint dryer
  • 1,543 Answers
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Posted on Sep 12, 2008
  • 943 Answers
3 Suggested Answers
  • 240 Answers
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
Posted on Feb 02, 2008
  • 38 Answers
SOURCE: hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Posted on Apr 24, 2009
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
I am looking to replace the heating element on an old hotpoint electric dryer and cannot locate how to find it.
Depends when the dryer was made, older models had the element at the front behind the front panel.
More recent models all have the element located at the rear of the dryer..
Hope this helps.
Dec 29, 2009 | Hotpoint Dryers
Hotpoint tdl52 no heat, element changed, but still will not heat
Check your all fuses that are suppose to protect your element. should have a high and low limit fuse
Aug 23, 2009 | Dryers
Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Jul 22, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
May 18, 2009 | Hotpoint Dryers
How do I find the element that turn up the heat or control the He
On most Hotpoint dryers the element and stats, are located behind a removable metal panel at rear of dryer., unscrew and check the compoents.Plz rate my solution
Dec 20, 2008 | Whirlpool LER5636P Electric Dryer
Hotpoint electric dryer model nvl333eb4cc not dryer clothes. where and how to check for the heating elements or any component that might be at fault
1. Reset a circuit breaker
2. To check the component you have to lift the top of the dryer.
3. all heating component located on the back of the drum.
4. The problem could be one of the safety thermostats or heating element.
5. To replace a heating element is to complicated if you do not have experience.
6. let me know if you going to do this
Nov 29, 2008 | Hotpoint Dryers
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Dec 29, 2006 | Hotpoint TDC32 Electric Dryer
Hotpoint NLL113EYWO Electric Dryer Logo
828 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
