Question about Yamaha RX-V661 Receiver
Subwoofer won't work after Auto Setup
I have the RX-V659 which is very similar to v661. After the auto setup, the subwoofer (Polk PSW404) will not work. During the auto setup, the sub works fine. I had the unit set up previously, and it worked great. I purchased a new plasma, and had to rearrange speakers and enterainment center. I cannot figure this out. I've tried manually changing the settings, but nothing seems to work.
Can anyone help me???
Thank you!
  • apmens Feb 06, 2009
    I have got the same problem mate. I had the receiver connected to two front speakers it was fine but after buying new subwoofer to connect it to the receiver during auto set up there was sound out put to the subwoofer but after the set up no sound through the subwoofer
Hi can you try this it might work, take off all the connections to your receiver and the reset your receiver to the original factory settings then turn it off and disconnect it from the socket. connect all the the speakers and turn on and start auto set up. hope it works
Posted on Feb 07, 2009
  • apmens Feb 10, 2009
    hi if it did not work disconnect all speakers and set all the front speakers to small and increase the frequency on the subwoofer to 90hz or more to determine if there is any sound. if you use the auto set up it normally sets the front speakers to large in that case there wouldn't be any low frequency to the subwoofer. finally touch the tip end of the RCA cable before connecting there should be a sound in that case the cable works also play music with big bass before you connect it. hope this can help you.
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Subwoofer set up polk audio 6750
Connect the subwoofer to an amplifier/audio receiver with the proper cables. Reply back with your setup so I can get some more information.
Dec 25, 2011 | Polk Audio Audio Players & Recorders
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
My model is RX-V665...not sure what the BL stands for... anyway...no sound from the subwoofer. Pull the RCA wire from the back of the receiver and touch it with my finder and you hear a buzz from the...
HI,
first of all select ur sub woofers auto mute (auto power off ) switch to off position.
then connect the mic and calibrate ur system one more time. after calibration select it to on position. u will surely get it work. if need any further assistance feel free to contact through fixya.
ok
Dec 31, 2010 | Yamaha RXV665BL Receiver
My polk psw404 has no power, I check the fuse at power source
Could be the power supply but the transformer may
have opened up due to a "surge". Might have to contact Polk to see whats up and/or dealer as the
amp may need sent in for repair!
May 24, 2010 | Polk Audio PSW404 Subwoofer
I cant seem to get the sub woofer to put out sound
Hello, are you using the subwoofer output on the receiver?
Did you turn the subwoofer on within the receivers onscreen setup?
this requires going into the menu selecting speaker setup and telling the receiver that you do have a subwoofer connected.
if you have done all this I would try to fist make sure the sub is working. easiest way is to plug a source directly into the rca inputs of the sub and see if it powers up. A CD player or even an ipod with the right connector will work.
if the sub powers on and produces sound then the issue is in the receiver and you will have to play with the setup. Its possible that the output jack is bad, I've had that happen when I pulled on an RCA cable and pulled out the socket but that's rare.
Is the subwoofer set to turn on automaticly when a signal is sensed?
does it have a switch to select high or low level inputs (speaker jacks or RCA connections on the back)
hope that helps
remember start by making sure the sub works then figure out why the receiver isn't sending a signal.
Feb 19, 2010 | Yamaha RX-V661 Receiver
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
Feb 14, 2009 | Yamaha RX-V661 Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Yamaha RX-V661 Receiver Logo
424 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
