Question about Ricoh FT5832 Copier
Error codes hi sir, our photocopies ft 3713 is not functioning because of E54, what shoul i do to remove it and make our machine fuction.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you sure this is a Ricoh copier?  Usually Ricoh copiers have error codes that start with SC.  Toshiba and some Imagistics copiers have error codes that start with E.
  • Tim Babcock
    We were looking this one up.  I believe that error code has to do with the fuser.
  • 97 Answers
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Posted on Sep 23, 2008
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
What is error code E000003-0002 on cannon irc 3380i
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Apr 21, 2015 | Cannon Office Equipment & Supplies
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
Error code e54
TEST this steps and fix it. This error code is E54 which is something to do with the motor.What you can try first is pull machine out and take off the back panel. From there you will see the motor at the bottom. Unplug the wiring block from it and start the machine again.
Jul 23, 2013 | Zanussi Washing Machines
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
Ricoh ft 3813 error E54
E54 is a fusing error. You can attempt to reset the code by entering service modes. To do that, you press CLEAR MODES key, then the numbers 1, 0, and 7 and then hold down STOP key. Once in service mode, press 97 then #. That resets the code. Power the machine off then back on to see if it comes back. If it does, then you may need main board or AC driver board.
Mar 14, 2011 | Ricoh FT3713 Copier
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
Ricoh FT5832 Copier Logo
184 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
