Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer I have no panel lights and dryer won't work. The door light comes on though. Can you help with this problem?
  • 2 more comments
  • tooxskelly Sep 16, 2008
    No display? Is it the electronic controller or has someone seen another problem. I do have AC to the controller.
  • Anonymous Sep 20, 2008
    INSIDE LIGHT COMES ON BUT DISPLAY PANEL NO LIGHTS DRYER WILL NOT COME ON
  • slm37 Sep 23, 2008
    The dryer control panel is completely nonresponsive and appears to be dead. As a result the dryer is nonfunctioning. However, the internal light turns on when door is opened, so it appears the dryer is receiving power.
  • JeffreyP Jan 31, 2009
    Maytag MDE4658AYW Electric Dryer - interior lights up, control panel is unresponsive. It was working this morning, then just went dead. Circuit breaker is fine, power is fine; obviously power to machine. Called Maytag; they said "you've described it exactly; the control panel is dead." Told me there's nothing I can do. I'm about to call Sears, where I have it under a service contract, but figured I'd let you know.
  • 943 Answers
HI FOR THIS PROBLEM I WOULD CHECK THE POWER SOURCE AT DRYER
Posted on Sep 12, 2008
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My whirlpool duet front load dryer will not turn on. the light is on inside the dryer, but the panel won't light up
Sounds like the door is not closing completely. Check the connectors that tell the unit the door is closed.
May 27, 2011 | Dryers
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Led light panel inop.Dryer won't come on but the light in the drum comes on when opening the dryer door.
my guess the door switch. here is a website that will explain how to test it. if you do not know how to open the dryer then scroll down an click open a cabinet. Hope this helped Tim
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
