Question about Panasonic DMR-E75VEG-S DVD Recorder/VCR
Recording & erasing problems
I have a set of DVD-RWs that I've been using with my Panasonic recorder for a few months. They've all worked fine until about a week ago, when the recorder stopped recognizing ALL of them. Sometimes it will let me view them, but most of the time it says there is a format error. The unit will no longer record on DVD-RWs. However, it still records on regular DVD-Rs. What could be causing this problem, and how can I fix it?
    President:
  • 3,130 Answers
Could be a cleaning issue or the laser is weak or out of alighnment and if you dont have a service manual and at least a 60 meg scope your gonna need to take in the unit to an authorized repair center. Good Luck
Posted on May 02, 2006
How do i unfinalise a dvd on Panasonic DMR-EZ47V DVD Recorder
The answer is in the question, u cant unfinalize, finalizing ends the session, DVD-Rs need to be finalized so they can be watched, DVD-RWs can usually be watched with out finalizing, so can be wiped & used again or added to later, Rs can only be written to once RWs can be used again providing u dont finalize them.
Jan 20, 2017 | Panasonic Televison & Video
Disc Error problem
Hello sir ,
When did u buy the system ???
Mar 13, 2008 | Sony RDR-VX500 DVD Recorder/VCR
White colour displaying as pink on DVD recorder DMR-EX77EB, problem just started a few weeks ago.
Very similar problem with my DMR-EZ27. About 10 minutes into playing back a DVD the color starts going away until I only see a black/white movie. Sometimes color comes back in partially then back to b/w
Feb 13, 2011 | Panasonic DMR-EZ48VK DVD Recorder
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic DMR-EH58- is recording only in B&W
The camera system was bought in USA. Changed output (in system settings) in DVD player to NTSC. Works fine now.
Apr 17, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Intermittent Recording
in you menu change your video format , check all settings,what type disc are you using ? are you recording to hd or to dvd, ? check your
firmware update
still have problems call 0403960527 jeff
email jcshepard55@hotmail.com
Feb 16, 2009 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Remote doesn't work for DVD Recorder
It is now working. The DVD is below a Panasonic TV. We blocked the tv remote sensor and the DVD remote started working. We have unblocked the tv sensor and the dvd remote is still working. I'm not sure what was wrong or how exactly we fixed it.
Jan 28, 2009 | Televison & Video
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
During scheduled recording for 1 1/2 hours, chanell changes
I called panasonic and they sent me @ no charge a cd update that fixed my problem. I talked to
John @ 1-800-211-7262 ext 5070. He seemed very knowledgeable and spoke ENGLISH!
This cd may fix other problems for this model.
Dec 26, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-E75VEG-S DVD Recorder/VCR Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
