Tommy Bahama TB2082 Watch for Women Logo
Posted on Sep 04, 2011
I got the watch at Costco and it was one of the last ones in stock from the display case so it didnt come with a manual. I don't understand exactly hat the buttons on the top and bottom of the main wind knob do exactly. I also can't figure out how to set it on the day without changing the numerical date. In other words get them in synch. Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
919
Points
You may search online on Google there are many solutions available online for bast clothing that suits your personality you have it on got apparel....
http://www.gotapparel.com
1helpful
Went 'swimming' in the dead sea... after having my battery changed.. with a rep dealer??.... but the salt water got in... perhaps he didnt replace the O rings....can I salvage my watch?...
your watch has only to be cleaned. don't lose hope on that. bring it to watch expert, explain what happened. and i'm sure it can be fix. i hope i had been helped you.
Sep 05, 2011 • Watches
1helpful
How do I display multiple lap times? I push the lap button and get the first lap time but I don't know how to see the subsequent laps.
From Timex: You cannot recall the laps on the expedition watch. You can only view the last lap run and the split time.
22helpful
2answers
I don't have an instruction manual for Zoo York
have a zoo york watch and I can't understand the directions
Aug 10, 2011 • Watches
How do i change the battery?
If you have a Timex digital watch, the back of your watch is probably attached with four little screws, one at each corner of the case. If you remove the screws, the back of the case should lift off with only a little nudge in case some grunge has glued the back to the rest of the case.
On the other hand, if you have an analog Timex watch (i.e., one with a traditional face), it almost certainly has a snap-fit case; the back is simply pressed back into position with firm pressure. The problem is that modern snap-fit case backs are often very tightly fitted to increase their water-resistance--they're tough to get off, and even tougher to push back into position. I would not be surprised if you will ultimately need a jeweler's case press to get the back of this watch back into place (more on this later).
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. Many Timex watches with snap-fit cases have a small triangle / pointer etched into the case back to suggest where you should fit a case knife to pop off the watch. If you don't see that small raised section or a marker, you'll need to choose a location to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose.
If you can't press the back on securely after replacing the battery, you will need to use a case press to complete the job. A case press is just what it sounds like: a device for clamping watch cases back together. It's designed to provide an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). I'm aware of two basic styles. One style looks vaguely like a big pair of pliers, but with two swiveling plates instead plier jaws. The other style, which I prefer, sits on a table or workbench and uses a lever to push down the top plate. In both cases, nylon jigs are inserted to match the size of your watch.
You can find case knives, case presses, and other watch repair tools at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
If you can't close the watch case with your bare hands and don't have access to a case press, your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
7helpful
How do I open the back of the Acqua Indiglo watch so I can change the CR2016 battery?
Your watch has a snap-fit case; the back is simply pressed back into position with firm pressure. The problem is that modern snap-fit case backs are often very tightly fitted to increase their water-resistance--they're tough to get off, and even tougher to push back into position. I would not be surprised if you will ultimately need a jeweler's case press to get the back of this watch back into place (more on this later).
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. Many Timex watches have a small triangle / pointer etched into the case back to suggest where you should fit a case knife to pop off the watch. If you don't see that small raised section or a marker (Aqua is a discount brand of Timex), you'll need to choose a location to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose.
May 29, 2011 • Watches
1helpful
CANNOT GET BACK OPEN TO REPLACE BATTERY
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off. Pictures I've seen of your specific watch suggest to me that you have a snap-fit case back, though I'll include instructions about a screw-on back, just in case I'm wrong.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, modern snap-fit case backs are often very tightly fitted--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
If, on the other hand, you have a case back with notches in it, you will need to unscrew the back of the watch. You'll need a special wrench to do this. There are lots of makers and models from a basic $5 "watch crab" to a $100 workbench-mounted device that works on all kinds of watches, including Rolexes. Again, because screw backs are usually tightly fastened to increase water resistance, simply using a pair of needle-nose pliers in the ridges probably won't work. Nor will using a screwdriver in one notch--these backs are designed to move when equal pressure is applied around the edges, and applying force in one area only locks things up. Under no circumstances try to pry off the back if you have a screw back -- this will damage the threads, and you'll probably never be able to get the watch back together again.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for a pretty reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
I have a Kenneth Cole KC1683 watch. I don't understand what the dial at the top left does. There are 3 dials. The main one has the hour and minute hands. There is another small one for the seconds....
It is the dual time zone dial. Set it for another timezone, like London or whatever you're interested in, a timezone your friend is in so you don't call them at 3 in the morning.
Top Tommy Bahama Watches Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
k24674
Are you a Tommy Bahama Watch Expert? Answer questions, earn points and help others
