Question about Plantronics Explorer 330 Headset
Setting up headset with treo
When I go to select handfree device - model 330 - I am not able to write on my treo pad under show trusted devices. do I need a password to connect also?
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Not sure which Palm Treo you have, but after reading through some of the info on the different sites it states that some bluetooth devices were easily installed and others were not. It may be one of the Treo's that may need an application to download an update. Some of these were released according to the information I read, that did not have DUN installed. Whether this has anything to do with pairing your bluetooth device, I am not sure. I couldn't find a spec page for your application. Usually it is just a simple matter of going to the bluetooth application on your phone and turning on your bluetooth headset. They find each other and you have success. I would recommend talking to Plantronics tech help line at 800-544-4660 x 5538.
Good luck from Headsets Direct!
Posted on Nov 02, 2011
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
Nortel T7316E, How to make headset work ?
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
  1. Press Function **266344
  2. Than enter system coordinator pass word
  3. Press SHOW once and enter your phone extension number
  4. Press SHOW twice
  5. Press NEXT tree times
  6. Change the parameter at HANDFREE with MOD
  7. Set it at AUTO
I beleved this will FIX it OK!
Jan 28, 2009 | Lands Phones
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Problem setting up bluetooth device with Palm Treo
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Jan 15, 2009 | Palm Treo 700w Bluetooth GPS GPS Receiver
220 Plantronics stopped working
Look under my name and find the previous 10-20 posts helping others with similar problems on adding/removing the existing connected device. However the Plantronics 220 Express and regular have connection problems with phones if they are far away, and sometimes get corrupt, unfortunately, for a $28.00 headset, its build for $28.00 of use.
Please review my previous posts and see if this can help you at all..
ManOwar
Aug 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
CONNECTION TO HEADSET
It should be under Menu/Connectivity/Bluetooth/Bluetooth select ON, then, My phone's visibility select Shown to all, then, My phone's name give it a name IE. Fred (you can change the name as often as you like).
There are two tabs where you are now, select the left one, go into Options select New paired device. Your phone will search for other devices, when it finds one you can pair the two, a pin number will be asked, keep things simple choose 0000 for both devices.
Mar 11, 2008 | Nokia N73 Cellular Phone
Palm Treo 650 doesn't see bluetooth headsets, AND wired headphone jack is shorted
Had a similar problems. Throw out wired headsets with shorting problems. Their too cheap to try and fix.
Try rebooting the phone, then make sure the wireless headset is on. The trick is to get it into "trusted devices", so when you get the phone to seek new or nearby devices, you need to push the button on the earpiece so it sends a signal at the time the phone is trying to find it. It took me a number of trys, but finally got it to work. I use Verizon and they were quite helpful, even though the phone was "out of warrenty". I was re-activating my phone after not using it for a couple of years.
Mar 08, 2008 | Palm Treo 650 Handheld
MOBILE PHONE NOKIA
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Plantronics Explorer  330 Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
