Question about Ovens
GE 24" Oven
Oven turns on and warms up,but it doesn't heat up enough to cook anything
  • 126 Answers
THE TEMP IN THE OVEN IS CONTROLLED BY A THERMOSTAT.IT GOES FAULTY IN TWO WAYS.IT EITHER OVER HEATS OR UNDER HEATS IN YOUR CASE ITS SOUNDS LIKE ITS UNDER HEATIN.BEST YOU GET A TECHNICIAN TO CHECK IT AND CHANGE IT FOR YOU.GOOD LUCK.MOHAMED
Posted on Sep 12, 2008
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
May 14, 2017 | GE 30" Built-In Single Electric Wall Oven...
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Oct 09, 2007 | Ovens
Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
76 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
