-   The lead vocals are minimal. Backup vocals comes thru loud and clear. I have a set of Bose Computer MusicMonitor.-   TannerBig
Mar 26, 2008
-   I got the same problem couple weeks ago, and i tried everything possible such formatting, upgrade it, i also made the rocovery thing, but nothing worked... what should we do??? -   anitaorozco
Feb 06, 2008
-   Thats my problem right now with the microphoto - Muted voices and distorted music. Kinda like an echo chamber. Reformatted the drive, new headphones - the drive seems to be fine - because I transferred a few songs to my office computer and they are fine. I think its something in the circuitry. Creative wants $135 to fix it - along with $25 to mail it. I can get a Nano for less.
-   ya its the same i can hear all the music but the words are really really low nd kind of crackly.i've changed the earphones and everything but it still the same-   Traceyxxx
I've had that problem when I first got my MP3 Player. I figured out 2 days later I didn't plug the headphones in right. Funny thing, I almost returned it. If thats not it change the settings like the other guy said.
Found your question due to having the exact problem you described. New firmware, format... loaded new music, same problem. While switching to yet another set of headphones the sound got better momentarily. The case doesn't appear loose, but squeeze right next to the lcd and lyra name and the audio was fixed. For some reason the audio was mechanical sounding and the voice was almost non-existant unless pressure was placed on the player where described. I tightened the screw in the retaining strap hole and the one under the USB connector flap and all is well for now. Good Luck!!!!
hi it can be a bad fault or just bad headphones first look in the SOUND settings if all the TRABLE, MID & BASS are fully up especially the MID which is the voice range... then cange the headphones
and if nothing works reset, format and copy all the songs again
Vocals are almost always in the center of the sound field. This means the same amount of vocal sound is going to both headsets. If you are hearing lots of music and not much vocal, I suspect the ground lead of your headphones (or the MP3 player headphone jack) has an open circuit. This can cause the vocals to cancel out, but you will still hear the music. This can be made even worse if your MP3 player has a "stereo wide" or "stereo enhance" setting that's turned on. "Stereo wide" plays some games with signal phase to create an illusion of more left-to-right separation, but if there is a connection problem with your phones or speakers, it will sound really odd.
It could also mean that your headphones are improperly built or plugged in...make sure they are all the way plugged in, and if that doesn't work, do exactly as windman says because he is a MASTER at fixya, this is just me favorite hobby...helping people.
mine used 2 let me put songs on then when a switched in on it wud say updating library 4 ages then...
(More)
mine used 2 let me put songs on then when a switched in on it wud say updating library 4 ages then stay like tht until i re set it. then did the sme wen a switched it bck on. wuddnt mind but onli had it since feb and cost me £60
Hello When I turn on the MP3 player it comes on and flashes through different colours and tells me...
(More)
Hello When I turn on the MP3 player it comes on and flashes through different colours and tells me it is locked and turns it self off.
I just purchased a Thomson Lyra 6675 (2Gb). Loaded some mp3 files on it in sequence. Play sequence...
(More)
I just purchased a Thomson Lyra 6675 (2Gb). Loaded some mp3 files on it in sequence. Play sequence is set to normal. I don;t know what order it is playing the files back in. It is not file create date, load sequence or alphabetic sequence. For listening to books, not having the tracks in sequence is a problem! Can you advise how I can get it to play in order? Thanks
I've put a 2gb sd memory card in my lyra...i've transferred 922mb and now it does not accept any...
(More)
I've put a 2gb sd memory card in my lyra...i've transferred 922mb and now it does not accept any more files...is it set to read up to 1gb memory sd cards?? thanks
