Question about Whirlpool Calypso GVW9959K Top Load Washer
Material getting caught
When washing sheets, or material of the same density, they get caught between the wash plate and the basket, around the rubber washer. I'm not sure if I need to replace the wash plate or some other part. I'd appreciate any help or info you can provide.
  • 2 more comments
  • DiLuna Sep 12, 2008
    I have it on automatic water level. I'm wondering if the washer plate has come loose or whatever holds it in place might be worn.
  • whisper4739 Sep 16, 2008
    I have the same issue with cloths getting caught. The seal between the washplate and drum looks to be 1/2 to 3/4 inch. I have the washplate on order and will advise when replaced.
  • Anonymous Sep 16, 2008
    I am having th same problem - light weight table cloths are being sucked below the washer plate and it is very difficult to get them pulled out. I am calling repair today.
  • DiLuna Sep 25, 2008
    I have found the same problem. The seal was broken and the u-joint assembly looks terrible. I have the parts but cant get the spanner nut off. I have soaked it with WD40 and tried heat. Nothing seems to loosen it. The next thing is to tru to cut the nut off. At this point I may even try a 1/4 stick of dynamite. (LOL)
From Whisper4739:
I replaced the washplate and also found the internal washplate mech to be damaged. The seal had broken and water had erroded the whole assembly. I replaced both internal and outer wash plates and this fixed the washer. I have found out from another poster that this was a recall by sears, so I'm going to contact sears to see if they will pay for the parts I purchased.
I think any black oil spots that others were getting could be fro the deteriation of the internal wash mech.
Posted on Sep 22, 2008
  • whisper4739 Sep 25, 2008
    I had to cut it off with my dremil tool. Cut 2 sides 180 degrees apart where the internal threads have a gap. I also had a hard time trying to torq the replacement nut to the number of foot pounds on the directions. I cranked as hard as i could and hopefully that will be good enough. Once this repair goes the machine is gone. good luck.
    Novelist:
    Champion:
  • 261 Answers
Sears has issued a service flash on this appliance, when you call you tell them what is here as this problem is a well known recall. The washplate and ccu have to be changed.
Posted on Sep 20, 2008
  • John Robbins
    John Robbins Sep 23, 2008
    There is a washplate retro kit that has beefier bolts with a wash plate that is a smidge wider. When I do this I also replace the boot and leveler inside the nutate dome. If debris is coming from internal leveler then there would be audible squeaks as well the wash plate would not return to its full level position. Black smudges is soap debris that has collected grease from us and dirt which starts to mildew which is the number 1 smell in these machines.
  • John Robbins
    John Robbins Sep 26, 2008
    When the spanner nut is froze rust remover works with a few taps of a hammer, I use my 2 piece spanner wrench.
  • 126 Answers
ARE YOU SELECTING THE RIGHT AMOUNT OF WATER.AND MAKE SURE THE HIGHT OF THE CLOTHING IS NOT TO HIGH.
Posted on Sep 12, 2008
An article of clothing went underneath the washng plate in my kenmore elite calypso washer. How do I get it out?
At the bottom take the cap off and you will see a bolt that needs to be removed then the plate comes off
Jul 17, 2015 | Kenmore Washing Machines
After 20 years of use, pieces of thin black rubber are deposited around the bowl after the wash cycle. Where is this material coming from?
are you sure that it is rubber
the black is mostly from the mud build up under the agitator from using washing powders that do not completely flush out on the spin cycle. Remove the agitator and /or bowl to clean out the gunk
after 20 years you will be amazed at how dirty the machine is where you can't see
Apr 09, 2015 | Washing Machines
How many dry cups would be in a 13.2 bag of dry kibble dog food? Thanks!
depends how big thee 'cup' is.easy to work out though. Get a bowl, weigh out a kilo, see how many cups that kilo fills then multiply that number by 13.2
Mar 02, 2015 | Dogs
Had repairman fix my disherwasher few days ago not draining. Now it's noisy while washing which was quiet before
Look around the bottom of the tub for foreign material, like a knife, spoon, nut or bolt.
I think if the repairman had "done it", it would have acted up immediately.
Also, look for anything sticking below the basket that might be interferring with the washer arm that spins around, too.
Jul 20, 2014 | KitchenAid Dishwashers
I want to buy a picnic basket for my friends as a wedding present. Should it be made from wicker?
Picnic baskets can be made from whatever material you like, but wicker has the advantage of being really sturdy and durable and it also looks good. Picnic baskets get carried around on outings and you need a strong material that won't start falling apart too quickly.
Feb 27, 2013 | Home
I have a bosch classixx 1200 when i wash a load of whites there is often a small amount of dark spots of deposit on the sheets if this is wiped off when wet it rubs into the material if we wait until dry...
Yes - I get this - you have to wipe the inside of the drum rubber ring - not just throught the groves but sludge seems to collect in between the rubber ring and metal drum; you will need quite a bit of kitchen towel!
Nov 09, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washer has trouble spnning
Ensure the basket is centered within the case, they can get tilted buy heavy objects washed or spun inside. A little force may be required to center the basket by grabbing the top of the basket sides and wiggling.
Inspect for a sock or other material caught betwen the basket & case around the top under the gasket.
Nov 04, 2009 | Kenmore 24902 Top Load Washer
Clutch rattle
no there is not a kit available. I have tried it myself before and used other spec material for the damper in the clutch and made the rivets myself. Worked great but is very timely. I'd actually recommend buying a new basket. The side pedals on the original basket often get grooves from the clutch plates wearing on them which can cause clutch chatter too.
Dec 05, 2008 | 1975 kawasaki Z1B
Washer ate a sheet
the wash plate has a rubber seal all the way around the bottom even the smallest gap can grab clothes and pull the under only solution is replace plate
Aug 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
