Hello MR dricha
Your page have many good idea
want to ask why richo aficio 1085 always need to do toner program to have good contrast
  • 3 more comments
  • ma7moud fayed Sep 17, 2008
    yes
  • ma7moud fayed Oct 11, 2008
    i replaced developer type 14 i think its the problem i think it need type 21
  • ma7moud fayed Oct 12, 2008
    many thanks for your replay its soo kind of you
    every time you replay
    many thanks
  • Tim Babcock
    Tim Babcock May 11, 2010
    What toner program are you running?
  • Tim Babcock
    Has the developer been changed?
  • 2,794 Answers
If the developer has been changed.  You need to go into service mode to calibrate it before you print.  If you don't run the program and you make copies, copy quality will change and you may have to replace the developer again.
Once it is replaced go into service mode and issue the service code to calibrate the developer.
If you haven't replaced the developer yet, you should.
Posted on Sep 18, 2008
  • Tim Babcock
    Tim Babcock Oct 11, 2008
    That could be a problem if it isn't the right toner.  I can look up the correct one you need on Monday if you need that information.
How to fix sc990 on richo 1085 copier
Have you done the PM? If not perform PM.
Feb 20, 2015 | Ricoh Aficio 1085 Laser Printer
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Jun 30, 2009 | Ricoh Aficio 1085 Laser Printer
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
Hello Bubba
yes it have Fiery EB 105e
Dec 08, 2008 | Office Equipment & Supplies
Hiricho aficio 1085
you need to activate scan to folder feature, under system properties
Aficio 1085 toner pread in drum area
the blade is not sitting correctly either you have used a bad one or the mechanism is not adhereing closely to the drum, removed the uit and rotate towards you sprinkle a few toner if you can still see a remainder toner that was not yet scraped then the prob is really in the cleaning unit, either the blade or the plate,
to ensure have you consider changing your drum? it could be exhausted already...
no other way around it
Nov 28, 2008 | Ricoh Aficio 1085 Laser Printer
Hello Bubbab
http://www.timatech.com/products.php?pd_pn=PAN064-CP
Sep 17, 2008 | Office Equipment & Supplies
Hello MR dricha
The firmware is only available on Ricoh service website. You have to be an authorized service technician to get in. It also require a special flash memory card that is pcmcia based as well as a $300 software program to put it in for a company in Germany. It's better to find a technician in your area to do it. You may find another solution around by checking out copytechnet.com. It's a free website for copy technicians. There maybe a Ricoh technician who can assist you on there.
Sep 12, 2008 | Ricoh Aficio 1035 Copier
91 people viewed this question
jasbo
jasbo
