KitchenAid KGHS01P Gas Dryer Logo
Posted on Sep 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a KitchenAid KGHS01P gas dryer. It runs, but no heat. We took the back off, cleaned out all the lint and the "ey" and it worked. As soon as we moved it back in place, the heat is gone again
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 04, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636215
Points
7414
This tip i wrote covers the usual things that could be wrong with a gas dryer and how to check them.
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
I hope it helps you to fix your's and please fell free to respond (add comment) if you cant figure something out.
GENE
My kenmore 750 series gas dryer wont heat
Here is the problem I think you have. Weak aged solenoids.
If a dryer produces some heat then their are 2 scenarios. It is clogged with lint, or the gas operator solenoids are getting hot and failing.Here is 2 of my home made videos. One shows basically before and after clean up and the other shows how to check and replace them coils:
More gas dryer enlightenment
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We have a KitchenAid KGHS01P that is running fine, but no heat. We took the back off and cleaned it, including the "eye". It worked fine when we tested it, but as soon as we moved it back in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Sep 04, 2011 • Dryers
Dryer dose not want to turn on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 • Dryers
Dryer won't heat? Lint screen is clean, duct is
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
2answers
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
2answers
Dryer runs fine but no heat
change the fuse in back of the dryer
Top KitchenAid Dryers Experts
Virgil Watts
Mike Cairns
Mike Cairns
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
