Question about Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Samsung Flat screen 100hz tv - no power
Samsung WS28A116T ( 100hz flat screen CRT ) Power button on tv has no effect. Plug fuse changed and different plug sockets used but still no difference. Any ideas????
  • 1 more comment
  • Anonymous Jun 03, 2008
    i Have the TV 56" flat Scren he Recib Power, bad is not audio not video is Samsung,
  • Anonymous Feb 03, 2009
    The power button will not turn the television on at all. It did, but took 1-4 hours to come on.
  • cddesmity Feb 03, 2009
    power button wont come on.
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
Posted on Aug 11, 2008
I havee a 42in samsung flatscreenn whenn i turn it on it has no picture with a humming noisee?
Posted on Dec 03, 2009
    President:
  • 3,130 Answers
Was the fuse blown?? if it was then you may have a current limitor block resistor that could have opened up as maybe the bridge recifyers are bad. If you measure the voltage on the inside you should have about 145 to 160 vdc on the main filter cap. If thats good then your switching supplys not working andf your gonna need a schematic as well as a meter and possibly a scope and an isolation xformer to trouble shoot this set. If ytou dont have these things call in a good local repair senter to assist you with an estimate. Good Luck.
Posted on May 02, 2006
SOURCE:
Samsung LE32A4566C2D flat screen tv wont turn on?
There is a chance the power supply is fried. However, I've seen some Samsung power supplies that have fusible resistors in the power supply for added protection. So your main fuse could be ok, but there could be an additional fusible resistor in the board as well. Also be aware, depending on where the surge entered the TV, you could also have a defective main board. Not trying to rain on your parade, but surge damage can sometimes be severe.
Dec 09, 2012 | Samsung Televison & Video
Tv shut down replaced burnt fuse but burns again when plug into power supply. what should I do my mom is in her seventies and missing her programs...
i would replace the fuse again and try a different outlet to rule out an electrical problem with that particular outlet. if it blows the fuse in a different outlet it's probably time to retire that TV set it's hard to find anyone to work on them anymore because they've become obsolete due to the flat screens.
Jul 31, 2012 | GE 25GT240 25" TV
KONKA flat-screen 26" model KL26AS22U: no
I'm sorry that the TV is not turning ON as expected. Please follow the below troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Try connecting to a different wall outlet to make sure that the issue is not with the power.
  3. Check for any burning spots on the board of the TV.
  4. Check the voltage level of the each board with the help of a multimeter.
Thanks for understanding.
Dec 02, 2011 | Konka Televison & Video
Samsung flat screen TV no picture
a capactor( look like battries either black or brown ) has blown on main power board you will need a soldering iron you can tell whitch one by the shape of the top and look for raised top replace it with same one and note what side the line is on and put new one in same way
Nov 28, 2009 | Televison & Video
Can't get power on tv
They do not use circuit breakers only fuses. The fuse is on the power supply board where the cable from the AC box plugs connects to the board. If the fuse doesnt fix it the power supply board will probably have to be replaced, if not one of the other boards may also be damaged.
May 26, 2009 | V, Inc. Vizio P50HD Plasma Television
Is the LED light on? If not then the Power supply may be bad. Try to unplug the TV and then plug back in. There is a fuse near the AC input. Check the fuse If the fuse is OK then the Power supply has gone bad.
Apr 01, 2009 | V, Inc. Vizio P50HD Plasma Television
How do change tv to run on 100hz from 50hz?
MrMark - Samantha is not talking about power, she's talking about the screen refresh rate. Quick to belittle...and wrong.
Jan 30, 2009 | Televison & Video
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung TXN3298HF 32" Flat CRT is dead, please help
Hi I have a Samsung Tantus Dynaflat 32 inch flat screen TXN3298hf that all of a sudden stopped working...no power no nothing. We opened up the back and found that a 5 amp fuse had blow. This fuse regulates that power supply to the tv and can be found at the end of the power cord prior to the circuit board. Hope this helps.
Jan 22, 2007 | Samsung TXN3298HF 32" TV
Samsung CXM2785TP 27 in. TV/VCR/DVD Combo Logo
2,256 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
