My Samsung is dark only when display PC, watching TV, Video is normal. Color are OK - not lines, no dot no pink or color subdues.
I dissemble the monitor and found 1 CCFL out of 4 is completely dead, there's another 1 (that paired with the dead one) is on and off and that one is on when in TV/Video mode and off in PC mode. So, I went ahead and changed all the CCFL bulbs and they come on nicely - all4 of them in every mode but the monitor is still dark in PC mode not the others.
-   hi im using samsung crt monitor but i am using tv along with pc but two days before when im try to on my pc its showing differrent color dark pink. but when im doing on tv then its normal. i checked resolution its fine. now what should i do plz sujjest me -   bhupender_ku
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see
I hooked a different monitor to my HP computer and the icons and pictures on the monitor look ****...
(More)
I hooked a different monitor to my HP computer and the icons and pictures on the monitor look **** comic drawings insted of sharp pictures like the old monitor. How do I fix this?
My brand new Apple LED cinema display produces a constant popping sound like others have reported...
(More)
My brand new Apple LED cinema display produces a constant popping sound like others have reported using this display and even with other manufacturer's displays/TVs? Is this truly a heating/cooling issue or is it power supply related?
My monitor is driving me crazy! after about a half hour it goes screwy! The best way I can describe...
(More)
My monitor is driving me crazy! after about a half hour it goes screwy! The best way I can describe it would be a colored negative, lowering the contrast on the screen makes it a little bearable, though it's still too distorted for reading. Funny thing is, after I turn it off for a couple hours it goes back to normal and then the process repeats itself.
