Question about Garmin 010-00358-00 GPS Receiver
Nuvi 200 does not charge all the way only 2 bars at a time
  • Garmin Master
  • 2,130 Answers
How are you charging it? With the computer? Some computers have a limited amount of current on the USB port. The best way to charge it is with the car adapter or wall charger. if that doesn't work, then you may need a new battery.
- Jim
Posted on Sep 12, 2008
I have a new Garmin NUVI 57 LM. I have it plugged into my computer to charge. How long should it take to get charged?
Charging via a PC is not the quickest way to charge a GPS because many USB ports can not supply enough current, so the battery will take longer to charge. Using an AC adapter is a better way. Leaving the unit to charge over night should be fine. The way to tell if the GPS is fully charged is to look at the battery icon on the main screen of the GPS. It consists of 4 bars. 4 bars = fully charged. 3 bars = 75%, 2 bars = 50% and 1 bar = 25%.
Nov 26, 2016 | Garmin nuvi 57 5" GPS
How much time is it to charge th nuvi 215
Typically charging overnight is good enough. Look to see if the battery icon located in the upper right hand corner of the main screen is at a full (4) bars. The icon is divided into (4) bars. The Nuvi 215 is a pretty old unit. If the battery hasn't been changed within 2 years it needs to be. Old batteries can leak and bloat (swell up). They will also not be able to be fully charged and will lose power very quickly. For more information on battery replacement, please see this link:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 10, 2014 | Garmin nuvi 215 GPS Receiver
I have had my garmin nuvi 200 for almost a year now and only recently it has been acting up. i have been going the same route for a few days so i have an idea on where i am going and where i need to turn....
your battery is low on power and needs to be fully charged. It may be that your battery needs changing.
DC does not fully charge it and also starting the engine while plugged in will eventually ruin the battery and affect the sirf chip. Charge it on AC or via the USB
Please rate my help++++Thanks for using FIXYA
Dec 05, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
First time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Jul 10, 2008 | Garmin nuvi 200W GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
