Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Lamp timer How do I reset my lamp timer on my panasonic PT-52LCX15 DLP
  • stevebert Jan 28, 2009
    I had the lamp replaced several months ago, but now the television is saying that the lamp needs to be replaced and the timer reset.  Is it possible that the technician replaced the lamp but failed to reset the timer or is the new lamp just going bad somehow.  There no indication that the lamp is failing, the TV turns on in the normal amount of warm-up time.  I'm just wondering if this is a bogus message, like the 60,000 mile "check engine" light in cars.
  • 50 Answers
Hold the Volume Down button on the TV and the Mute button on the remote for 5 seconds.
Posted on Mar 10, 2010
Reset timer panasonic d6000
Hello!
Have you bought bare lamp? Probably, yes. And not from "Panasonic"? yes. The timer's reset procedure is different for every model of Panasonic, including TVs. when you buy lamp with housing from Panasonic, they will give you the directions, how to. If it's "aftermarket", nope!
http://www.manualowl.com/m/Panasonic/PT-D5600U/Manual/52045
that's where you will find the procedure. it's quite complicated, page 45.
follow the directions.
good luck,
Alex.
Dec 27, 2011 | Panasonic PT-D5600U DLP Projector
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
47in dlp tv that turns on then shuts back off
The lamp may be bad or a fan has stopped running. Remove your lamp and see if it's shattered or dark and gray in the center. Also your lamp timer could have reached it's limit. check your manual to see how you can reset the timer only if the lamp looks clear.
Jan 29, 2010 | Panasonic PT-47X54 47" Rear Projection...
How do I reset the lamp timer on my panasonic dlp tv?
Most Panasonic lamp driven TV's use either the PIP or SPLIT button on the remote control pressed simultaneously with the VOLUME down on the TV. These two buttons must be held in that position for more than 6 seconds then a box should appear on the screen letting you know the timer was reset to zero. The instructions usually come with the lamp as they are not in the owners manual. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Panasonic PT-56DLX75 56" HDTV
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
I have a panasonic model pt-52lcx15 and replaced the lamp part # ty-la1000. It works fine but I can't figure out how to reset the timer, do you have instructions for this, they weren't included with the...
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Jan 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
405 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
