Our GE washer WASE5210B3WW will only go in the rinse and final spin cycle when turned on.
  • 943 Answers
HI THANKS FOR YOUR QUESTION ,wHEN YOU SELECT nORMAL WASH dOESWATER COME IN. IF NO LOOK AT THE WAETER TEM SETTINGS YOU HAVE SELECTED iF THE WATER TEMP SELECTOR IS SET FOR HOT AND NO WATER CHANGE THE WATER TEMP TO WARM IF COLD ONLY COMES IN YOU NEED A WATER VALVE .tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Posted on Sep 12, 2008
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Final rinse cycle never engages
does all the water drain out? will the machine spin on any cycle? does the timer advance to off?
if the lid switch fails to activate then it would not let your machine spin on any cycle.
you should also check to see if cold water is coming into the machine. most machines rinse on cold water and if the water valve for the cold side fails - this could also be a cause.
May 29, 2010 | GE WDSR2080D Top Load Washer
Washer will not do final spin
If the washer will spin between wash and rinse cycles and on another cycle like perm. press or heavy duty, then the timer is probably bad. If everything works on another cycle, you can use the machine while you save for another one, or can find a new timer for the one you have. Best of luck
Mar 21, 2010 | GE Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Dec 13, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
