Question about Maytag MZD2766GES Side by Side Refrigerator
Defrost Problem I havea Maytag MSD 2456DE side by side. The freezer is not properly defrosting and this impacts the temperature of the refrigerator. I've defrosted it manually three times in as many weeks. What is the most likely cause...thermostat? circuit board? Do you know how to determine which it is? - JoDawg
  • JoDawg Sep 14, 2008
    Thanks....we'll give it a go. :-)
    Champion:
  • 210 Answers
The first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Posted on Sep 13, 2008
  • i'm sorry, the adaptive defrost board, not the main circuit board.
I have a Maytag side by side refridge Model # MSD 2436GRW The refirdge side does not feel like it is cooling properly- I have had to move the dial up tp 8-9
There are many different ways a refrigerator will do this. But I will focus on the most likely and that will be either the 68233-2 Defrost Timer or the=> 61005989 Auto Damper Click Here=> MSD2436GRW_Controls and in that photo you will see the location's 13 and 8. Here are the instructions for testing the auto damper=> 61005989 Auto Damper Test Instructions Look into the rear of your freezer and tell me if ice or a layer of frost is covering the rear panel. If yes try to turn the defrost timer clockwise slowly untill refrigerator stops or manually defrost with a hair dryer. If the refrigerator defrost after turning defrost timer then just replace timer. Refrigerator will usally take 25 minutes after that time the refrigerator does not come on simply turn th timer clockwise until it starts. If defrost is not the problem then it is time to test the auto damper. There are a few other test like testing the defrost heater= HERE Here is the freezer compartment parts breakdown=> MSD2436GRW_Freezer_Compartment and part 12 in that photo is the=> 61006116 Defrost Heater Assembly with Defrost Thermostat
I will be here on Fixya or Here if you have questions, Thanks Sea Breeze
If helpful please rate this solution.. Thank You
Jul 19, 2011 | Maytag Refrigerators
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Was cooling then the refrigerator started not cooling then the freezer begain not to cool and i thank the fan started freezing up.p/s its a mds 2456de
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 25, 2010 | Maytag Refrigerators
Model # MSD2757AEW this is a side by side, the
Because you mentioned that last week you had an ice problem I need to ask was anything done to fix or check the defrost system? The number one reason for this is the Adaptive Defrost Control part number 61005988 If this is OK then we need to check the defrost heater and defrost thermostat. The ADC is located inside the fresh food compartment and behind the control panel used to adjust the temperatures in the freezer and refrigerator. I will be here if you need my help, Thanks, Sea Breeze
Adaptive Defrost Assembly P/N: 61005988
PART NUMBER AND MODEL SEARCH FEATURE
Jul 21, 2009 | Maytag Refrigerators
Freezer not properly defrosting
On the adaptive defrost control board...cut the orange/white wire.
This will put the board into a standard 8 hour defrost cycle.
Mar 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Jun 10, 2008 | Maytag Refrigerators
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
Maytag MZD2766GES Side by Side Refrigerator Logo
210 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
