Question about Amana AGR5735QDS Gas Kitchen Range
Amana gas range short; model number AGR5735QDB
When baking with this gas range there seems to be a short when you have two pans in the oven. It produces a large spark across the window and trips the breaker. Any help would be appreciated. Thanks for reading.
  • reid184 Sep 12, 2008
    Everything else works fine. This is the first problem that we have encountered.
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Posted on Nov 12, 2007
SOURCE: amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Posted on Nov 17, 2008
fixyourboard
  • 310 Answers
SOURCE: Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Posted on Jul 21, 2009
SOURCE: amana gas range will not heat in "bake" mode.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Oven shuts off intermittently during baking.
Number 2 is the oven sensor. If it is shorted or open or out of spec (1100 ohms @ 75f) then it won't let the control operate right. If that is ok the ignitor /glowbar might be getting weak. When these get weak you can sometimes bump the valve and make it light. themobilian_2911.jpg
Aug 25, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
I have an Amana acf3325a gas range. the oven will
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace. Part number is 74008064.
Keep in mind, ignitors are fragile.
Dec 28, 2009 | Amana ACF3325 Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana oven does not work.
the most likly problem is the bake ignitor is bad. this is a common part to fail in gas ovens. the bake ignitor part number for your model is 31940001, and price ranges from $45-$75. a bad clock can also cause this issue, but I would start with the ignitor. let me know if you have further questions. shane
Jun 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Amana agr5735qds oven will not light.  broiler works as do all the burners.
There are two igniters in your oven one for bake and one for broil. The bake igniter very likely needs to be replaced. Igniter part number is 70080764.
Dec 13, 2008 | Amana AGR5735QDS Gas Kitchen Range
Amana AGR5735QDS Gas Kitchen Range Logo
125 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
