Question about Proview PL713S 17" Flat Panel LCD Monitor
Displays a red laser like vertical thread
When I started my computer the monitor Displays a red laser-like vertical thread from the bottom to approx. 2" from the top. The artifact appears to be in a layer above the display.
    Champion:
  • 293 Answers
Hi...there,
Well...your lucks just run out...It's seems your panel are damaged. Repaired...don't bother, the panel cost twices what you paid for your monitor itself. Get a new one...and you'll saved the $$$ and all headaches...
Posted on Nov 21, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
There are two vertical lines on my lg flatron w1942s monitor one is red and other is green line
Go to the buttons on the bottom of your monitor it will give you an option to change the vertical and horizontal setting.
Mar 12, 2011 | LG W1942S 19" LCD Monitor
My acer monitor has a vertical red line, about 3 inches long, starting from the bottom of the 23" screen. It is definitely the monitor because when I disconnect it from the computer, the red line...
If there's a minute fracture in the control array, you could find that one of the transistor control lines has failed. Basically, you've got a grid of transistors, with wires connecting them, behind the monitor. Specialised control systems and timing keeps them working, but basically, it's a load of wires turning on and off. If one of those wires gets damaged (From you saying that red is on permanently, it could be a short on the red pixel line) then you get the symptoms you saw.
Mar 10, 2011 | Acer 19" LCD Monitor
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
51 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
