Back to:
Tags:
Brother SX-4000 Typewriter
Brother sx-4000 typewriter
posted by puddin on May 01, 2006
When i turn on typewriter it starts making a clicking noise and won't stop. The codes on typewriter are as followed. pitch 10, line 1, and word spell.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 01, 2006
Thanks for Trying (70)
techman
Rank:Guru Guru
Rating: 87%, 6804 votes
you have a gremlin in your typwritter?? No you may though have a few stuck buttons as I used to fix these word processors all the time and that was very common. If thats not the problem then its in the controller assy PCB and its expensive as every board on this unit is only replaceable as an assy. IF its available!! you could call the main support # in your owners manual and see what they tell ya or call here. 800-276-7746 Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on brother sx-4000 typewriter:
I don't want to Accept this solution
Solution #2
posted on Sep 18, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
We are getting half letters...only the tops. Any soultion? It a brand new machine we just took it out of the box.
Thank You!
Can you Help with these Typewriters problems?
For view mode I key code plus m and nothing happens after...
I replaced a new ribbon typewriter and the keys hit the...
Can you send me some instructions on how to access the...
I believe the carriage stopper fell off. How do I put it...
The display on my SX-4000 will not clear. It has...
Loading problems.
Repair Service
Find Typewriter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
