Question about Whirlpool Washing Machines
Fault code 32 for new whirlpool frontload washer, machine turns on, acts like it wants to work, then shuts down.
  • 126 Answers
WITH REGARDS TO ALL LATEST WHIRLPOOL APPLIANCES BEING A WHIRLPOOL AGENT IN SOUTH AFRICA WE HAVE FOUND THAT NOT ALL TECHNICHANS CAN REPAIR THEM AS WE ARE EQUIPED WITH A HAND HELD COMPUTER THAT ALLOWS US TO REPAIR AND REPROGRAM ANY APPLIANCE THAT GIVES THE CUSTOMER A FAULT CODE CHEAPER AND QUICKER.SO ITS BEST YOU CALL A AGENT NEAR YOU.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
What does Lc mean on my Whirlpool frontload washer?
lock
LoC or LC - Whirlpool Home Appliances
producthelp.whirlpool.com/Troubleshooting...Front_Load_Washers/.../LoC_or_LCApr 22, 2017 - If you try to push buttons, you may see the code "LoC" or "LC" ... For each second CONTROL LOCK is held down, the display will count ... You may still touch START to pause the cycle, or touch POWER to turn off the washer.
What does Lc mean on my Whirlpool front load washer Google Search
Jun 24, 2017 | Whirlpool Washing Machines
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
