Question about Video Game Consoles & Games
The disk dont spin on ps2 and makes a vibrating sound
  • ty-guy009 Dec 07, 2008
    the disq wont spin and the display show no data
    Problem Solver:
  • 16 Answers
Putt it in so the tiitle is facing you
Posted on Sep 12, 2008
When i turn my game on it say system configuration i dont know what it means it dont go to disc main menue
Sounds like your laser is burnt out. In that event the system does not know that a disk has been inserted. Or the disk does not spin because spindle motor burnt out. If you can hear disc spinning the laser is at fault. You can purchase replacements on ebay. Good Luck.
Nov 23, 2009 | Sony PlayStation 2 (PS2) Console
PS2 will not read any disks
you probably will have to take it to get it repaired because its not the disks it your console for sure so try getting it repaired or getting a new one
Aug 04, 2009 | Sony PlayStation 2 (PS2) Console
Disc not spinnig on ps2
Make sure that the disc is placed all the way in the spindle. Check to make sure the disk isn't scratched or damaged.
Sep 22, 2008 | Sony PlayStation 2 (PS2) Console
Won't work. disk won't turn
sounds like a faulty spindle. this is the part that spins your cd for the laser to read. if your using a fat ps2 its prolly the spindle. if your using a slim ps2 it could be the laser causing the problem not the spindle. the slim ps2 laser make the spindle work. if the laser isnt working right the cd might not spin or it might not spin fast enough or flat enough.
look
Mar 06, 2008 | Microsoft Xbox 360 Console
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 wont work
it might just be that the laser needs cleaning if you can here the disk spinning round then this is probably the case you can by a lense cleaner and it is best to get a good quality one if this dont solve the problem then it is the laser unit itself take the case off wen unplugged and see where the laser is it should be in the middle by the disk that the game sits on if its not gently push it back to the start position and then put it back together and try your game if this still dont work then you will need a new laser unit but make sure u get the right one for your model u can fit these yourself but will need to get it re calibrated it is best to get someone to do this for you hope this is some help
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
My ps2 wont work
THIS IS DEFFINETLY A FAULTY LASER REPLACE WITH A NEW LASER AND PS2 WILL WORK FINE
May 26, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
