Question about RCA HD61LPW42 61" Rear Projection HDTV
Shrinking Picture RCA HD61LPW42 has a dark area in the upper left side of the screen and there seems to be a shrinking of the picture on the right side leaving a verticle line at the right screen edge. Picture is also not quite as bright as it used to be.
  • Jim Rose May 01, 2006
    Thanks for the fast reply--- I'll probably wait till it gets worse before I do anything. It's just starting to become noticible.
    JR
  • Anonymous Mar 15, 2014
    screen will not shrink
Triangular shadow in the left corner is a light engine problem,,, not available!!!! This unit can be repaired by Electronic Services in Fort Smith AR. (479 7835930) if you can remove it and ship it to them..
Posted on Mar 21, 2007
    President:
  • 3,130 Answers
Sounds like your main power supplyis going bad . It supose to be 130 dc but I'll bet its down to around 90 to 100 volts!!! its probably the main filter cap or the regulator IC . hard to say without measureing the b+ good luck
Posted on May 01, 2006
TV Picture shrinks down more and more until it gets to a line.
You may have a cold solder joint around the Vertical circuit. Resolder the pins of the LA7833 IC and the components around the IC.
Check the C308 220uf/35V & C320 100uf/50V.
Nous Sabre.
www.aaatvservice.com
Jan 28, 2012 | Toshiba 32A33 32" TV
My hdtv picture is shrinking
flyback transformer or the equivalent IC needs to be changed ( some brands use and IC rather than a transformer)
Sep 22, 2009 | Televison & Video
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
RCA picture problem
Hi
This is vertical issue, your unit have problem in vertical section. this is Changed Value resistor, this needs to replaced a new one.
Thanks!
Nov 28, 2008 | Televison & Video
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Screen is cutting off the sides
That is an ITC008 chassis and the problem you're referring to is called a breathing picture. One fault I am aware of in this chassis/model is the connector Bl103. I have seen a couple where the connector failed and had to be replaced. Could open it up and locate the conntector and see if it's vibration sensitive.
Bill
Apr 26, 2008 | RCA 32V550T 32" TV
PICTure is shrinking on the side of my 32 inch toshiba help is there anything i can do
Check power supply capacitors with ESR meter, esp. regulator
circuits.............verify model # off back to proceed...T.
Nov 30, 2007 | Toshiba 32AF43 32" TV
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
RCA HD61LPW42 61" Rear Projection HDTV Logo
263 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
