Question about Denon AVR-982 Receiver
Denon AVR-982 Receiver has 3 Optical Inputs that do not work. Is there a module that I can buy to fix the problem? Thanks
    President:
  • 3,130 Answers
I tryed to look up this model but didnt find it??? HMM ok the optical inputs are sensitive and were you using them?? and then they went out or have they ever worked??? I would open the unit to see if there is a plug or cable disconnected or loose on the input PCB. If that dosent help you probably have a b+ feed issue as all three use the same b+.. your gonna need to contact the manufacturer for service or viset an authorized repair center unless you can get a schematic and trouble shoot it yourself.. Contact www.contactservice@denonnj.com Good Luck
Posted on Apr 30, 2006
I have a Denon AVR-2801. I use an optical cable from the TV for Audio Out to the receiver. I set the receiver to TV/DBS but when it comes on, it just says TV and I get no sound from the receiver to
You need to do the input assign. The receiver doesn't yet know that you plugged a cable in to one of the Optical ports.
If you have done the above, then the next thing is to check the amp's Mode button. This cycles the input between Optical and analogue audio inputs.
Sep 05, 2014 | Denon AVR-2801 Receiver
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
Feb 09, 2018 | Denon AVR-2802
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 15, 2011 | Denon AVR-3200 Receiver
I have connected an audio source to the optical input channel 3 on my Denon AVR3300 but cannot get any audio thru mu speakers. The CD and Blueray connected to channels 1 and 2 work fine. What other...
If you have the User Guide for the Denon 3300, go to the "setting the digital inputs" section. The input settings are in the on screen menu called "system setup menu", then move down to "digital inputs".
Make sure that input you are having problems with is selected properly to "Optical".
The Denon 3300 guide is a mess I know and not user friendly in the least.
I have been using the 3300 for 9 plus years with no failures.
Oct 13, 2010 | Denon AVR-3300 Receiver
Hi, i have the Denon AVR-2802 reciver. My issue is when i plug my xbox into the dvd compontent inputs, i cant get any audio or video. I was working a few days ago, i had to disconnect the amp, when i...
Component inputs are for video only, and when connected through a receiver then the television also must have a video input coming to it from the video out from the receiver. If you want audio that will be a separate connection from the xbox to the receiver either by digital coaxial cable or optical cable, or composite.
Dec 15, 2009 | Denon AVR-2802
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
My Denon AVR 2106 gives sound out periodically in all modes
So you have no sound on any Inputs?  This makes a difference, if it works on some inputs but not others.  For a factory reset - turn the unit off by the ON/OFF button (not the standby button) hold in the SPEAkER A & B buttons at the smae time, while pressing them turn the system on by the ON/OFF button, wait about 3 seconds and the unit should reset everything.
Jan 01, 2009 | Denon AVR-2106 Receiver
Denon AVR-982 Receiver Logo
167 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
