Question about KitchenAid Washing Machines
Clutch is bad - KitchenAid Washing Machines
  • 943 Answers
ON WHAT PLEASE
Posted on Sep 12, 2008
2002 jeep liberty ac clutch not engaging
Could just be low on refrigerant, bad relay, or bad clutch. You can buy a can of r134a that comes with gauge to check refrigerant. You can swap the relay with the horn relay if refrigerant is good to test it.
Jul 03, 2016 | 2002 Jeep Liberty
Why is the clutch not engaging when a/c is turned on?
bad clutch; bad coil in clutch; no power to energize clutch no refrigerant in system and more
Jun 18, 2015 | 2003 Ford Escape
THE CLUTCH ON MY 96 NISSAN 200SX SE STICKS WHEN I SHIFT AND ONLY HAS A LITTLE PAY WHERE THE CLUTCH ENGAGES
Could be clutch cable adjustment needed. Could be bad clutch cable bad or linkages to. If noisy bad throughout bearing. How many miles on clutch? could be worn out and need to be changed.
Mar 06, 2015 | 1996 Nissan 200SX
I have a cub cadet 2542 shaft driven lawn tractor. The PTO will not engage the blades what could be wrong?
bad relay or bad pto clutch to check clutch jump from battery to clutch electrical connector at clutch see if clutch engages if it does bad relay or bad switch if it doesnt bad clutch
Jul 22, 2014 | Garden
How to change the a/c compressor clutch?
changing the clutch does not require flushing system. only time system is flushed is when compressor goes bad but you are doing just the clutch. how much more for compressor and are you sure compressor is good? why did clutch go bad? most clutches go bad due to bad compressor, they burn out ,unless it just shorted and wont engage.
Jun 29, 2013 | 2002 Ford Mustang
Clutch slips on 96 geo prizm.
usually a slipping clutch is a bad clutch
the acid test is to remove the slave
point car in safe direction ,
start car in gear, does it slip now?
yes, then the clutch is bad.
you do this test off road safely..
it can only be 2 things, think about it.
1: bad clutch 99%
2; a seized ,while extended slave.
Feb 08, 2013 | 1997 Geo Prizm
Clutch doesnt work,has new clutch and master cylinder.pushes down and doesnt return up.
the problem is most likley a bad clutch slave cylnder or bad clutch master cyl. or you have air inline
Jul 05, 2012 | 1983 Nissan 280ZX
85 hilux 4x4 have no clutch when checking found fluid leaking from rubber boot at the arm pretruding from gear box how do you repair this? cheers roger
bad slave cylinder possible. may even be a bad clutch master cylinder.was leaking from firewall? not bad clutch mastercylinder. was leaking under car on passenger side at front of tranny, but in between motor and tranny where motor bolts to transmission? most likely, bad clutch slave cylinder. having to add brake fluid to clutch master cylinder? having to pump the clutch pedal up to shift gears? either you have a bad clutch slave cylinder[leaking under the car between motor and tranmission] or leaking on firewall [the wall that under dash and under the front window] you may even need a clutch replacement.3 if you need further assistment,repost your question to fixya.com
Dec 26, 2010 | 1985 Toyota 4Runner
I have a 82 v45 magna that has the same problem with the clutch aswell,it has no pressure we tried to bleed it and did it the correct way but now i have nothing in the clutch?
Either has a bad clutch master cylinder, or a bad slave cylinder. If you can line lock the clutch, does it have good pressure? If not, you need a clutch master, if so, it is slave cylinder, or a bad clutch.
Aug 03, 2009 | 1982 Honda VF 750 S
Clutch pedal goes to floor
Its sounds like a bad clutch cylinder or bad slave cylinder or fluid leaking. First check brake fluid level in clutch master , and check for a leak in clutch system. If there are NO leaks, then you either have a bad clutch cylinder or a slave cylinder. Bleed clutch at bleeder screw on slave cylinder and make sure there is pressure from master cylinder. If there is pressure then slave cylinder may be bad replace slave and bleed and that should take care of you problem. If master is bad then replace bleed system ad you should be good. Contact if you need more help. Thanks for using FIX YA.
May 16, 2009 | 1988 Honda Accord 4 Door
Washing Machines Logo
21 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
