Question about HP DeskJet 5550 InkJet Printer
Top light with (x) blinking
This problem started after a jam. The next time I tried, the second sheet jammed. The printer appears to collect jobs and reports them but will not print them. Several sheets appeared to print but then had nothing on the paper when they came through. I have turned printer off several times and even unplugged from the wall outlet for over ten minutes, shuffled paper in tray, etc. HELP ! :< (
Fixed this problem this morning by unplugging the printer from the computer, plugging it back in and changing out both cartridges (color and black) and replacing with new cartridges.
Don't know which helped. I had been unplugging the computer from the power source but not the printer from the computer.
My four year old printer is still cranking - good open forum you provide here. Thank you !
In that spirit, I decided to contribute my update ..... Judy
Posted on Sep 15, 2008
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
    Issue
    The power light and resume light is blinking.
    Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
    Load paper in the paper tray and press the resume button (c01219285.bmp ).
    Try to print the job. If the issue continues, proceed to the next step.
    Solution two: Clear the paper jam
    Step one: Clear the jam from the back and top of the product
    1. Remove any paper loaded in the output tray.
    2. Turn off the product.
    3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
    4. Locate any jammed paper inside the product and pull it out towards you.
    5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
    6. If the jam is there, carefully remove any jammed paper and close the cover.
    7. Replace the rear access panel or duplex unit.
    8. Open the top cover.
    9. Check for and remove any jammed paper by gently pulling it out.
    10. Make sure that there are no scraps of paper stuck between the rollers.
    11. Close the top cover, turn on the product, and resend the print job.
    Try to print the job again. If the issue continues, proceed to the next step.
    Step three: Service the printer
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Cause
    The product might be out of paper or there might be a paper jam.
    Feb 28, 2011 | Office Equipment & Supplies
    Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
    I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
    Nothing else for it with your, take the drum and toner out and check for bits of paper.
    Mar 11, 2017 | Brother HL-5370DWT Laser Printer
    Machine has an error code & won't print. We have no manual.
    If the lamp is on solid that is a cancel job or reset printer indicator
    If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
    1 blink - jam in feeder sensor
    2 blink - jam in manual feed
    3 blink - jam under toner
    4 blink - jam in output are
    5 blink - jam in tray 1
    6 blink - jam in tray 2 (if present/option)
    Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
    Continuous Paper Jam
    Could try cleaning the peper feed rollers, may be debris on the feeders. Possibly could be damaged..
    Rich
    Aug 13, 2009 | Canon LaserBase MF5750 All-In-One Printer
    Constant yellow blinking light, no paper jam
    I found this on the HP support site:
    The power light is on, and the resume light is blinking.
    c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
    Solution
    Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
    Solution
    1. Remove the paper with fresh ink.
    2. Press the resume button.
    The printer might be out of paper.
    Solution
    1. Load paper in the paper tray.
    The printer might have a paper jam.
    Solution
    Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
    OR
    if the print carriage is stuck or making a grinding noise, then follow these steps.
    Solution
    1. Lift the top cover of the printer.
    2. Turn the printer off and then on again.
    3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
    4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
    5. Remove the print cartridges and close the top cover.
    6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
    7. Open the top cover, reinstall the print cartridges, and then close the top cover.
    The printer may be ready to eject banner paper.
    Solution
    Press the resume button to eject the banner paper.
    Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
    HP Laserjet 4L - Grinding or Growling noise when job sent to printer
    goto feedroller.com
    http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
    purchase a maintenance kit.
    replace the piper pickup roller.
    since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
    the job is not difficult, just time consuming.
    Nov 02, 2008 | HP LaserJet 4L Printer
    The top lights stays blinking and printer will not print
    Yes definetly,
    First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
    small part of papper jam in to the papper path or sensor earia
    or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
    vyas
    Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
    Blinking Lights and Grunge Noise
    Service time or replace it. If you are considering replacing it- you may well try to take top cover off to ensure there is nothing stuck.
    Apr 16, 2007 | Epson Stylus Photo R1800 InkJet Printer
    HP DeskJet 5550 InkJet Printer Logo
    37 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
