Question about Samsung LN-T4061F 40 in. LCD HDTV
Samsung HDTV issue
I got my TV 1 year ago and have used it a ton. Recently I have noticed it takes at least 15 seconds for my TV to turn on after I press the "ON" button. Should I be concerned that my TV is taking forever to turn on? How do I fix the problem? Is it worth fixing?
  • 2 more comments
  • Anonymous Mar 08, 2009
    tv comes on 2-5 minutes after pressing on button. It clicks several times and finally comes on. I have noticed the problem getting worse. Any input?
  • scsmith Apr 04, 2009
    Almost the same problem but now it seems like it clicks on and off forever and the picture never comes on. I can here the tv chime like it is coming on but then it clicks like it is turning off and starts all over. Again, no picture, no sound. Please help!
  • ctp_10 May 08, 2009
    my tv turns on..melogy rings and then turns off and then I hear the melody again...then the tv turns on and a picture is there
  • madiaz May 22, 2009
    I can't fall asleep without TV... It has clicked on and off for 1 and 1/2 hours.... wtf... Is there a reset button or something... UGh
Sounds like your power board, cost about $100.0 plus labor worth fixing
Posted on Apr 04, 2009
That is normal for this tv i thought i had the same problem but after playing nintendo wii on it now i have a real problem burnt in picture after playing nin-wii on it for about 4 hours
Posted on Jan 04, 2009
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung hlp4663 stand by light
I recently had this issue on my Samsung HL-R4667W. Did the new lamp (phillips) but it still wouldn't light up and was flashing the lamp light and then stanby. I started to remove the rear covers of the TV thinking maybe the wheel or ballast finally gave out. After removing the lower cover I noticed a wire hanging at a unusual angle from a circuit board. I touched it and it fell off. Traced the wire back to the main control board and found that it was a ground wire. I re-soldered it to the board and the TV fired right up. My other lamp was fine too. I hadn't moved the TV in 4 years and only once since I bought it in 2006 so I can't think of anything that would cause it to come loose short of bad soldering from the assembly line. That was a year ago and it works fine still.
Feb 10, 2014 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Noticed 2 white spots about a week ago.
It seems you have an issue with your DMD board, so pretty much you will need to replace it, those boards are running around 180 dlls, it's worth to try, but eventually you will need to give maintenance to the Tv
Jul 24, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Samsung LN-T4061F 40 in. LCD HDTV Logo
293 people viewed this question
Henry  Thomas
Henry Thomas
