DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Digital photo pictre frame wiil
By ikamt on Sep 12, 2008
digital photo pictre frame wiil not stay on. when turned on it starts and then its shuts down
Comments:
Sep 12, 2008
- As faor as I know there is not batteries. It is a Plug into power unit
Sep 12, 2008
- I think I'm taking to the wrong people. This is a digital photo frame that shows pictures from a memory card, It's not a dvd player. Please advise me to whom I need to comuicate with.
Thankyou
Sep 12, 2008
- Brand Polaroid
ref no. xsa 01010B
model 6081A
consumption < 18w
Sep 12, 2008
- I've had this unit about 1 year. The problem happened aout 1 month ago
Sep 12, 2008
- I just sent you all the information on the unit. AND IT IS NOT LINKED TO MY COMPUTER.
It operates on its own
Sep 12, 2008
- My picture frame does notneed to be connected to a computer. IT READS A MEMORY CARD.
Sep 12, 2008
- I'm waiting to hear from you on how to fix my photo frame. So far all you have done is get my money.
If you don't give me instructions on how to fix my problem, I would like my money refunded.
Thankyou
T Maki
Sep 13, 2008
- I don't know what I have to do to get through to what my problem is .I have sent you several e-mails discribing my problem.I also sent you the model number and serial number. All I want is for you to either tell what you think the problem is or return my money.
T Maki
Same Problem
Apr 17, 2009
-   I also have a polaroid picture frame model 6081A. Also this unit flashes for a moment the polaraoid start up screen and after that you can see there is info on the LCD screen without backlight. What is the problem? Is it possible to solve this backlight issue? -   Guest
Solution #1
posted on Sep 12, 2008
Somewhat Helpful)
mastersaintx
Rank: Wiz
Rating: 85%, 400 votes
You mentioned that your digital photoframe will not turn on. When you connect it to the computer see if the computer still detects it. You also mentioned that it is direct to AC power. The reasone the previous experts suggested this is because there are so many digital photo frames out in the market today as you did not specify your exact brand and model number we can only guess. So it is best if you specify your exact brand and model. Secondly I ask if the computer still detects the unit because that is a way to find out if the unit is defective or not. I would assume your unit still needs a computer to put pictures on it right? I stress the word assume because i do not know the brand and model.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
ginko
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 5080 votes
Check the power supply contacts, if it is battery one remove and put back the batteries, clean battery contact with alcohol.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
Kindofcheap
Rank: Wiz  Televisions & Videos  Expert
Rating: 80%, 74 votes
are you using a USB cable (make sure that the cable is 1.0 or 2.0) then see of the
dvd player supports both. If not you may be using the wrong USB i would just try a new
usb (spare)
Thank you Jayson
Comments:
Sep 12, 2008
- can you please display you model number thank you
Sep 12, 2008
- I need the name and model thank you
Sep 12, 2008
- no you are fine it is that you did not give out enough info about your problem
the screen is diplaying your problem as a Generic Dvd Problem thats all
we can still help you;)
Sep 12, 2008
- I am really having a hard time finding this Model Is this the Correct number
please just double check model Polaroid 6081A
Sep 12, 2008
- ok I am very sorry I have located it
You have a back compartment on the rear of the Frame
Are you using the AC plug to connect it to the wall out let
Sep 12, 2008
- you can hooked this up to a computer but that is not a problem
so is there a chance that yo may have another memory card to
try or is this card full
Sep 12, 2008
- Press and hold the MENU button for one second to access the On Screen Display (OSD). Press the or button to choose an item and press the Play ▶II button to enter. Press the or button to choose an option and press the Play OK button to confirm your choice.
Sep 12, 2008
- make sure that your wireless remote power button is not causing the problem
This may caused by an object laying on top of the remote power button
Simple but just a suggestion to check also that the power button is not sticking
Sep 12, 2008
Check the AC Power Input see if it is lose or the plug cord may have a small cut/slice
and the wire is exposed
Was this helpful?
Yes
No
Solution #4
posted on Sep 13, 2008
Not Rated)
Ajkill
Rating: 84%, 1103 votes
Well try connecting your photo frame to different ac mains and make sure your memory card as image in jpg format if this did not work then try to format the card and add some photos and check if its displayed on the frame ,even this fails then you get it serviced ,please use this number for the company support:
Contact Information
Phone: 1-866-289-5168
Good luck...
Was this helpful?
Yes
No
Solution #5
Not Rated)
Fixe_You
Rating: 82%, 1023 votes
chek if u can reset the unit or put it in the factory defaults.
if that not work ceck if u got a cd come with and a cable anything .. that u can upgrade it firmware with it sir!!
best regards
if this is not help tell me so i can help u further.
Was this helpful?
Yes
No
Solution #6
Not Rated)
abhishek33
Rating: 75%, 451 votes
HI   REMOVE THE MEMORY CARD &INSERT IT..   IF ALSO SAME PROBLEM TRY TO FORMAT THE MEMORY CARD.. THROUGH IT OR FROM CARD READER.. I WILL SOLVE THE PROBLEM.. PLEASE RATE IT.. THANK U.
Was this helpful?
Yes
No
Solution #7
Not Rated)
ohms
Rating: 83%, 784 votes
there's not much we can do about that digital frame. The PCB is the heart of the digital photo frame, as it includes the device software. If it malfunctions, that's it. Common issue with digital frames, burn-out, you'll know it when something smells like a plastic burning.
Was this helpful?
Yes
No
Solution #8
Not Rated)
leethedeuce
Rating: 86%, 495 votes
How long have you owned this unit for? When did you start having these problems. Once I have all the information I can assist you further. Please don't request more assistance/reject my assistance until I can assist you further.
Thanks,
lee
Comments:
Sep 12, 2008
- How long have you owned the unit? Also how long have you been having this problem?
Thanks,
Lee
Sep 12, 2008
- Phone: 1-866-289-5168
call this number for service and support the warranty on those is only 90 days. Not much of a warranty. usually though when you purchase it at most retailers you are offered a protection plan. I recommend it on frames like these. Newer technology that is made as cheap as possible to bring the price down. A protection plan only costs about 20$ and would allow you to replace your item for free. If you need any further assistance let me know.
Thanks,
Lee
Sep 12, 2008
- Can you see my solution I have advised you on the steps you need to take to fix your unit. If you have any questions for me still please let me know.
Thanks,
Lee
Was this helpful?
Yes
No
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Which is the Best and Lower Price DVD player
Answer
mi problema es la imagen en dvd no se ve, esta desincronizada
Answer
my kids went into setup on my ad1115 player made changes and now i get sound but no picture. how do... (More)
Answer
panasonic dmr-es46v dvd recorder / vcr combo will not play or record
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Players:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 800
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
