Question about Hitachi 50V500 50 in. HD-Ready LCD Television
TV locked Is there anyway to overide the passcode on a 46 Hitach HDTV, I cannot use any of the fuctions. in other words I have no graphics.I Is this something someone can assist me with. I just moved to a new location and my manual is packed.
  • sunshine1999 Sep 12, 2008
    Hi Benimur
    my model# is 50V569A, and how do I get to the custom menu?
    Thanks
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Pls postback the exact model number of the TV. Alternately, pls try on the original remote:
  • If QuickLock is activated it will lockout all video outputs and channel and channel 3 &4;
  • Get into the custom menu and select quick lock
  • Enter "0 0 0 0" as the 4 digit pass code;
  • turn off the parental lock feature
If the above does not work, then an internal fault has developed. On some models, the technically correct procedure would then be:
  • Check around the data and clock line and determine if the clock line was pulled to ground;
  • The easiest place to gain access to the clock and data line would be to go to IY501(18 & 19)
  • Floating these pins on IY501 and removed the "Child Lock" feature
  • Replace IY501;
  • The normal state on these two pins is 5 volts measured with a DVM, or 5 volts peak to peak with an oscilloscope;
  • This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 12, 2008
  • Louie  Role
    Louie Role Sep 13, 2008
    Appreciate the postback/comment and additional information on the specific model.
    To your concern:
    • reset the unit by unplugging from the mains for a couple of hours to dissipate residual power and revert unit to factory default;
    • in some versions/models, there are multiple locks: child lock, channel lock, video lock, quick lock;
    • on the original remote;
    To Cancel: (If Code has not been Changed)
    1) Select the channel that's locked.
    2) Press the MENU button
    3) Select SET UP then CHILD LOCK and CHILD LOCK CANCEL
    4) Press the ENTER button
    5) Press the ENTER button and the picture and sound return to normal
    6) Press the MENU button
    (For tomorrow, set CHILD LOCK again if necessary.
    To Cancel: (If Code has been Changed)
    5) Enter correct CODE
    6) Press the ENTER button and the picture and sound return to normal
    7) Press the MENU button
    If you've forgotten your Code.
    If "CHILD LOCK INCORRECT KEY NUMBER appears for a moment,
    it means that you have entered a wrong key number. Enter the correct
    number after this indication disappears. If you do not know the correct key number, enter 777.
    At this time your key number will be returned to the basic key number 000.
    If I may comment, the information on the model number (50V569A) you posted does not jive with your initial post of a 46 Hitach HDTV, however a 50V569A would indicate a 50 incher unit or would it be a 52in HDTV as you posted here. Pls bear with me and confirm the model number at the rear of the unit. A typical 46 inch Hitachi would have a model number like 46HDX62 or CMP460V1 or combination to that effect.
    Cheers.
Mitsubishi HD Diamond 1080 WS-55907
with the tv on, with the original mits remote, punch in this sequence menu, 8,2,7,0 the should bring up the option menu. the first line should have "initial" highlighted. if it does press "enter" on the remote. in a second or two the tv should switch to ant a probably channel 3. power the tv off then back on. this action puts the tv back to customer defaults, in other words just like it was when it came out of the box. there should be no passwords required.
good luck
Jun 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Televison & Video
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Televison & Video
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
Tip
Bypass Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Reset Mitsubishi HDTV VChip Password
I hope that helps.
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
I hope that helps.
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
215 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
