Question about Panasonic PT-51G53 51" Rear Projection Television
Sound but no picture
I noticed lately the picture had been shaking but just last night when I turned it on, the picture was good for about 5 minutes and then it went away leaving a small rainbow of color across the middle of the screen. I have perfect sound and sometimes the picture will reappear for a few minutes and it's gone again. Can you help?
  • 64 Answers
His is the vertical circuit going bad. you willl need a repairman for this. unless you can solder? a cost of repair might range around 400.00 good luck :)
Posted on May 02, 2006
    President:
  • 3,130 Answers
Was it shaking up and down or from side to side?? It could be a verticale sweep problem as thats the most common fault in this set and another one is the horizontal output goes bad because of a defective high voltage transformer. It could also have bad capacitors on the secondary side of the flyback switching supply. This is a hard call with out seeing a schematic. Good Luck.
Posted on May 01, 2006
99 Chevy Silverado 2500 was running fine last night..got gas last night but got it from the same gas station as always...thismorning idle was realy rough,shaking the whole truck...really struggling for...
Have you changed plugs and plug wires lately. Sounds like misfire, possible ! Should also check fuel pressure , plugged fuel filter or weak fuel pump ! Mass air flow sensor dirty, or map sensor .What engine do you have and does yours have How to replace the spider injector on Cheyv motor 4 3 or 5 7 liter
Jan 20, 2015 | 1999 Chevrolet Silverado 2500
I unknowingly spilled water on my Nikon Coolpix L120.
One thing I've done, which might be too late for is submerge my electronic device (cell phone, remote controls, etc) in 99% rubbing alcohol. The logic behind it is, alcohol is non conductive so it wont create shorts, combines with water and evaporates faster than water.
I think at this point your best option is to find something to draw the moisture out of the camera. You need to remove the battery until this process is done as well. Rice (dry uncooked) does a decent job of absorbing moisture. Whatever the case is, you will have to get all the optics cleaned after its dried out.
Jan 08, 2014 | Nikon Coolpix L120 L-120 26253 Black 21x...
I've had a Samsung HLR5064W for almost 5 years. Lately I've noticed when I turn the set on, the picture dims after about a minute. Is this a lamp issue??
Yes it's the lamp. I had the same issue in the middle of last year. I bought the whole bulb assembly for $220 Canadian. I'm confident that it was through Samsung USA.
I did find a site that said you could "save money" by buying the bulb only, but their price was the same for the bulb alone, as I paid for the whole assembly.
It took about 15 minutes to get the bad one out, and put the good one in.
Now I need to find out how to adjust the mirror angle...
Good luck
Oct 25, 2009 | Samsung HLR5064W DLP Projection TV
Refrigerator not cooling properly.
upper part feeses and bottom not verry cold at all
Aug 16, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Jun 01, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
No picture,but sound ok
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
May 11, 2008 | RCA D52W19 52" Rear Projection Television
RCA F36650 36
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor.
Jan 05, 2008 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Panasonic PT-51G53 51" Rear Projection Television Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
