Question about GoVideo Televison & Video
My dvd video player often won't read good discs as being good ans says they are "bad" or no disc when I know the one inside is ok. If I try multiple times it may work. Why and thanks for your help. Barbara
How do i find the lense ?
do i have to take the complete case apart ?
Help
I am neart boston
some of my previously recorded dvd's can not be read
i get empty dic : Message
am willing to pay reasonable fee for hands on solution
Posted on Oct 24, 2008
  • 37 Answers
Your DVD player is about to break completely. The disk is spinning too slow at times. I currently have a similar problem and have not yet determined if the motor is bad or the chip that drives the motor or the main processor chip. There is a slight possiblity that a poor power supply is at fault. Because of the high cost of repair it's probably not worth repair. Oh yes, one other possibility is the lens that reads the DVD may be dirty. You can try to clean it and see if it helps, Use a cotton swab with alcohol (not the kind you drink) and gently wipe the plastic lens the dry it with the dry end of the swab. Look closely to make sure you don't leave any cotton behind. You only need a little alcohol. Don't over due it. Good luck,
nssms
Posted on Sep 12, 2008
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
Need an answer about my Polaroid portable DVD player
either a dirty or bad optical pickup which reads the disc--if bad may not be economical to fix.
Apr 19, 2012 | Televison & Video
I tried to record a dvd and was unsucessful. Now the player won't work. I insert a disc and I can hear the player trying to read the disc. After three tries an error message is displayed saying:...
Hello
It seems that the Laser Pickup unit has some troouble with it. Just inser an audio CD and see whether the player reads the disc. If it reads, try with an MP3 disc. If these tow types of discs go with and not with DVD disc, make sure that the Laser Pickup Unit has the trouble. It has to be replaced with same type and number. Actually this is a very skilled work, as you have to disassemble and reassemble the DVD mechanism If you have confidence, and have all tools to do this work, you can do it by yoursef. Otherewise, get this set repaired, either by any experienced service technician, or by the Authorised Service Center for Panasonic at your town, I recomend you to get this set repaired by its authorised service center itself. OK.
Oct 26, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
When I put a dvd in it says "loading" for a good
Try cleaning the laser lens. Either opening the unit and cleaning with a cotton bud, or try a lens cleaning disk.
Oct 24, 2011 | Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
Samsung dvd player does not read dvd disc.it reads "no disc".
I also have a Samsung Dvd player. If it is a dvd you burned yourself it may not recognize the disc. If you have loaded a purchased or rented disc and it still won't load, I would say the head is dirty or the unit is defective. I would try a head cleaner first.available at most electronics stores If that doesn't work you probably will need to send it in for repair.
good luck
Apr 15, 2011 | Audio Players & Recorders
WHAT DVD DISCS WILL PLAY ON THIS DVD PLAYER
Assuming you are not having an actual hardware problem with the DVD player or an incompatible format (e.g. HD video & non-HD player); you should know that when you write video to DVD-R or DVD+R discs, you have to 'finalize' the discs on the creating drive for them to be playable on a regular DVD player. (Note a finalized disc can no longer be written to. If the player can read DVD-Ram (and your creating drive can write to them), DVD-Ram discs do not need to be finalized.)
Dec 21, 2008 | JVC HR-XVS20 DVD Player/VCR
Televison & Video Logo
53 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
