posted by Frederick on Apr 30, 2006
This is an old model we think possibly 25 years old.
It will run perfectly for some time, suddenly stop and will not perform.
It has been an excellent Air Conditioner, and we are not in a position to buy one at the moment, but would like to know if because of its age it is worth us having it serviced.
Best Solution
posted on Apr 30, 2006
You dont just add "GAS" to an a/c. First thing to do is to trouble shoot the unit!! When you turn the thermistat clock wish is it clicking ?? if not maybe its bad or open. If it is then turn the thermistate all the way to the left, turn on the A/C to cool. Then slowly turn up the thermistat and see if you hear the compressor comming on and staying on?? If you dont and you will if its working then you have a bad start cap or a wire is burnt off one of the terminals or the click-on inside the wireing cover is open.. Now if it starts and shuts off it could just be a capacitor or even the compressor its self. Iv'e use window shaker type a/c and repaired them for years in NYC and seem some really old ones that were condistion as these older units have copper cooling coils(eveporators) and copper exhaust coils(condenser coil) in the back and the front of the unit. Now days most manufacturers use aluminum coils and I think there garbage as they dont hold a charge for a long peroid of time and they glue them together. so remember thid\s when your looking for a replacement unit as it wont last but a few years if its aluminum!! Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Frederick,
If it work but you don't have a cold air, its look like you should add Gas. In case it doesn't work at all, it could be a problem with the power switch or in most of the cases it cause a capacitor that should be replaced.
Any of these repairs shouldn't be expensive (check costs with the technician). My opinion is not to replace a good horse !
Solution #4
posted on Dec 30, 2007
If the unit runs normally, no ice formed in evaporator and compressor suction or the unit is cold during operation then the system is normal.
- Check if the condenser is clean.
- Check if condenser fan motor work properly, check if the rpm. is normal.
- Check if the compressor amps. is normal.
- Check for out of range sensors/ thermostat.
- Check if the unit control is operating normally.
Solution #5
posted on Nov 29, 2007
THE UNIT NEEDS TO BE REPLACED FOR MILLIONS OF REASONS BUT IT SOUNDS LIKE YOUR PROBLEM WILL BE A SIMPLE ONE TO FIX VIA MAIL BUT I WILL NEED MORE QUESTIONS ANSWERD EMAIL ME AT DAMIEN@CONTRACTOR.NET IF YOU NEED THE HELP
Solution #6
posted on Aug 08, 2007
Well it is according to what part of it is not working. Recently I had to replace my blower motor in my central heat and air. It cost me 150.00 for the motor and I uninstalled it and installed it myself. I do business with a electric motor repair shop and they new exactly what it was and where to get it without going thru a shop or dealer. We went back with a heavier one that should give us many years of service.
Suggest a new solution for this problem
Post a New problem for Kenwood KW85 Air Conditioner
Email this problem
Email this problem
This Problem Also Relates To:
GE Deluxe AGM05LA Thru-Wall/Window Air Conditioner
GE Profile ASM10AA Air Conditioner
Panasonic CW-1406BU Air Conditioner
Panasonic CW-1805SU Air Conditioner
Panasonic CW-XC243HU Air Conditioner
Panasonic 9,800 Btu Room Air Conditioner with Touch Controls and Remote Control, CWXC104HU
Continental CE75106 Portable Air Conditioner
Can you Help with these Air Conditioners problems?
how do I vent exhaust hose with...
I have a problem installing... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
