Question about Toshiba 50H72 50" Rear Projection Television
Only half the screen is being projected?
Hi, when I turn on the tv, only the bottom half comes up. It is cut off with red, yellow, and blue lines directly in the middle. The top half is just black....
Please help
Exactly the same problem, First day went back to normal after a couple of minutes, second day took a little longer but worked fine ,Now is like that permanentlly
  • helpforus Sep 13, 2008
    I am hoping for a more specific answer, like, This problem is due to ....., and parts required are .....with labor should be about, $$$$$, so I know what to expect when a technician check my unit. If three people have posted the exact same problem I am hoping is not that rare. It looks like something I can't fix it myself, but I need to know, is it worth fixing it ,can I afford it? Thank you.
    Thank you, Now I know what to expect.
    Genius:
  • 2,920 Answers
It will cost between 300 and 400 to repair it sounds like diodes have gone bad in the tv.
Posted on Sep 13, 2008
  • Toshiba Master
  • 19,396 Answers
That is a convergence problem, as posted, it is called horizontal failure, to fix it it is necessary check soldering at the yokes, test horizontal convergence IC, test a couple of capacitors and resistors on convergence circuit, and sometimes the technician may have to replace a pcb inside.
The wole job starts from $80 and usually costs over $200.
To get service you can call the number listed on the owner manual, or look for support on website.
Let me know your location, and the current state of your guaranty if you wnat more information.
    Genius:
  • 1,239 Answers
HI      TRY TO OPEN IT IN A GOOD SUMMER OUTLET .. DUE TO SOME MOISTURE PROBLEM SOME RARE CASES ARE THERE.. IF I DON'T WORK'S MEAN THERE IS A PROBLEM IN THE LCD PIXCEL'S..  IF ANY ASSIST I AM THERE TO ASSIST U ..  THANK U
Posted on Sep 12, 2008
  • 2,322 Answers
The failure with your TV is best describe in the this link. This type of failure is common on rear projection TVs.
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Hitachi TV 43FDX10B has yellow line with blue curve line above it
It sounds like your convergence ic's are messing up
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Jan 27, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
i am having the same issue............any solutions??
Mar 31, 2008 | Toshiba 50H72 50" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
