Question about Lowrance GPS
I have a Lowrance LCX111HD and added a contour chip. How do you set unit up to download chip? I also received a fishing spot hot chip and cannot download chip data. Thanks
4 Suggested Answers
  • 16 Answers
SOURCE: fish finder
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
hydetech
  • 113 Answers
SOURCE: False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Posted on Feb 26, 2008
SOURCE: Troubleshooting my Lowrance LC X - 15MT Unit
lowrance mark 5x will not come on
Posted on Aug 22, 2011
How do I erase trails
http://www.lowrance.com/Global/Lowrance-images/backgrounds/lowrance_hds_background.jpg
Here is a link to the lowrance website to the elite 5 page where you can download a pdf file of your owners manual.
Go to your gps screen on your unit and press "menu" twice. Under the Chart heading you will find "waypoints, routes and trails" select this option and when you open it you will find a tab for trails this is where you will locate the options to delete your trails so they wont clutter your screen.
Dec 15, 2014 | Lowrance Elite 5 Color SonarGPS Combo
Tip
Lowrance X515C Manual Download
Download Lowrance X515C Manual
Models: X510C / X515C
Have you misplaced your Lowrance X515C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
__________________________________________
on May 06, 2010 | Boating
Tip
Lowrance X510C Manual Download
Download Lowrance X510C Manual
Have you misplaced your Lowrance X510C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
HDs 8--detecting bait fish?
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Feb 06, 2013 | Lowrance HDS-8
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
I have a Lowrance 7200C GPS (marine) unit with a "Navico 041-0680-17 chip. It doesnt show the depth contours, is there an upgrade or do I buy another chip? and if so, what chip will be best for my unit?...
Not showing the Depth Contours usually means it doesnt have that programmed on the chip.
The best Chips Ive ever seen, used or worked with for the Lowrance's are the "Navionics" and Fishing Hot Spots. Both can be obtained from Cabela's...either retail or online. And normally go from 99bucks for last years maps to 199 for this years. Hope this helps.
Oct 15, 2009 | Lowrance Globalmap 7200c Gps 7" Screen...
Where to put gps receiver, for fish finder, lowrance m52 s/gps
The receiver needs to be mounted so that it has a clear, unobstructed view of the sky. It will be fine through glass windshields, fiberglass and cloth tops. Keep it at least 2 feet away from the display unit.
Jun 30, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
GPS Logo
49 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
