Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
We had a carrier infinity system put in place 2 years ago. A week a go we had a system failure and notification on our screen for system malfunction. It turns out that the damper control module failed because of moisture under our crawl space. I then went under our crawl space to find that our unit is sweating like crazy and their is moisutre dripping in large amounts off all of the duct work. I was really sick to my stomach. Our insulation is falling off because it has become so wet. It really is a night mare. We lived in this home for 10 years and never had a moisture problem underneath. I confirmed with a general contractor that I do not have any plumbing leaks. The water is definitely coming from the system itself. The damper control module was installed under the crawl space and I have been informed that this should have been installed indoors in a closet. Also, the unit was layed horizontally and has only 1" clearance from the ground. I was told that this does not even meet code. I am convinced that the unit has been installed improperly. I am concerned about proper duct work, etc. What do you think?
  • 1 more comment
  • taxangel Sep 12, 2008
    Filters have been changed every time the screen says to change filters. The unit is still under warranty with sears. I guess I have to take it up with them to get the problem solved.
    Thanks for your help.
  • Bdamnd Sep 14, 2008
    The AC condenser in my attic is 14 years old. I have never had a problem with it sweating until this year. All of a sudden the unit, ducts, pipes and all are soaked, dripping onto my insulation and even through my ceiling. I have always cleaned the filter twice a year, no exception this year. I've added fans in the attic temporarily to supplement the power roof vent which helps with the problem, but I never added fans in previous years. I don't know why it's sweating now after 13 years of not sweating.
  • chwhite1036 Mar 27, 2009
    We have a similar problem.For 14 years we never had an issue. The a/c unit itself is outside and everything else is run in the attic as we have hot water heat. We started to notice a smell and everything in the attic was soaked. We had everything including the unit replaced and even had a heat pump add on and ran it for a few weeks after we shut off the a/c. We closed all of the ceiling vents. We turned off the boiler heat a few weeks ago,opened the vents and used the heat pump again this spring as we were advised. We instantly noticed the same smell and all of our duct work is once again wet. How could we have no problem for 14 years and all of a sudden things are getting soaked in one season?
If its an infinity. check and make sure you have a proper charge and no air infiltration from attic. also check blower speed on your humidity control in the controller set up
Posted on Aug 07, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Posted on Sep 12, 2008
2 Suggested Answers
  • 2976 Answers
SOURCE: new house & new heat pump and duct work sweating like crazy!
It shouldn't leak or sweat inside the building. Have the installer pay for a reinstallation by a qualified technician. Threaten them with small claims court and negative publicity. Both work quite well.
Posted on Jun 18, 2009
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Need to know what Carrier air handler will work with a 24ana760a003 Infinity? Please help
I am a Carrier Dealer. Here is your info 1 Model FE4a or FE5a The 5 is upflow only where the 4 is multi positional. F is fan coil E is Infinity A is series N is the voltage. By the way I have the Infinity series in my home it is quiet and very low cost on power bills if it is set up right. Most service techs dont like to work on them . They are very high tech. You will like it Rus
Jul 03, 2009 | Heating & Cooling
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
5,140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
