Question about Acer Aspire 3680 Laptop
2 operating systems
How can I safely remove windows vista I mistakenly thought I had to install because the disk came with.
t takes forever to start up -having to select the correct system first -not to mention all of the space it takes up.
Do I need a recovery disk?
maureen r
  • 749 Answers
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Posted on Oct 05, 2008
My dell won't reboot. Goes to a screen that says windows error recovery, and gives me two options.1. resume windows normally or 2. launch startup repair. I tried the 2nd one and nothing happens. It...
"Step 1
I would suggest you to boot the computer in safe mode and check if you can boot to the desktop and post back the result. To boot to the desktop in safe mode with networking keep tapping F8 key during restart. Once you see the option to boot in safe mode with networking select it and press enter.
Access the link to know more about how to boot the computer in safe mode:
http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
Step 2
If you are unable to boot to the computer in safe mode, you may try to perform a system restore from Windows Recovery Enviornment (WINRE Mode) to an earlier date and check if it helps you fix the issue.
If you have Windows Vista disk you may try to perform a system restore using Windows Vista disk:
a. Insert the installation disc.
b. Restart your computer.
c. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
d. Choose your language settings, and then click Next.
e. Click Repair your computer.
f. Select the operating system you want to repair, and then click Next.
g. On the System Recovery Options menu, click System restore and select the date when the computer was working fine.
If System Recovery Options is a preinstalled recovery option on your computer:
a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.
b. Do one of the following:
• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)
d. Select a keyboard layout, and then click next.
e. Select a user name and enter the password, and then click OK.
f. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
After running the system restore check if you can boot to the desktop normally.
Access the link below to find more information about system restore.
http://windows.microsoft.com/en-US/windows-vista/What-are-the-system-recovery-options-in-Windows-Vista
http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly "
This guide should help you out
Aug 24, 2011 | Dell Inspiron 1545 Notebook
My compaq presaria cq61 wont start up wt do i do it just goes looks like its loading up but it doesnt strat up and takes me to the safe mode seting but wont start in safe
there are number of reasons your windows want load up it could be hardware or software..
ok lets get to the point
start up the system press F8 advanced configuration then choice safe mode with networking or last good configurations hopefully you will manage to access your operating system remove any new driver or software or applications you installed recently it may be bad driver or program once you removed it restart the system and see if it works
1: Q1 what operating system are you using windows XP or vista , Windows 7 ....
May 02, 2011 | HP Compaq Presario CQ61420us Notebook
When you turn on the lap top it says operating system not found. I put recovery disk 1/3 in and it loads windows files. Then a screen pops up and says windows recovery center or repair windows. For more...
Do not press on F8. What you need to do is to do a start up repair. Select the option to repair the operating system. Then it will load some files. JUst wait for it to complete the loading process or the repair. It will tell if the repair is successful or not. If it doesn't fix the problem, then, you need to install the operating system to your computer. But, remember that operating system re-installation will return your computer to scratch. It will erase everything including the files and programs that you have added in your computer. But, if you don't have anything to lose then do the operating system reisntallation.
Here's a guide on how to reinstall windows vista:
http://www.blackviper.com/Articles/OS/InstallVista/installvista1.htm
Mar 22, 2011 | Sony Computers & Internet
HP Pavilion a6010n takes forever to boot to OEM Windows Vista disk
Yes it does - do not disrupt the operation in order to prevent future system operating errors. This is normal. If it fails, you will get a notification error and until then, please be patient. I'm assuming you are installing Windows Vista to upgrade from a previous operating system?
Dec 09, 2010 | HP Pavilion A6010N (882780985575) PC...
What tool do you recommend if you forget your VISTA password?
For recovering Windows logon Password safely, I recommend software program Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows logon Password. I wrote it to a Usb memory card. Booting up and clearing my password within just 4 minutes. You can Search Windows Password Seeker or download it from:http://www.passwordseeker.com
Aug 28, 2010 | Microsoft Windows Vista Ultimate Edition
When i power down my notebook, windows is not shutting down completely which causes a long power up. it came pre-installed. when i turn my computer back on, a screen appears stating windows did not...
First, run a scan disk/check disk option. You usually get prompted for this upon a reboot.
Second, if that doesn't work, windows is smart enough to create a few restore points when new drivers/updates are installed. Open up an explorer window (like my computer or my documents, not internet explorer) and press F1 for the help display. Search for system restore. It's very user friendly, so it should be pretty easy to find it
Jun 11, 2009 | Microsoft Windows Vista Ultimate Edition
Rebooting.
Rebooting a computer will not remove your Windows Vista Operating System, So, it is safe to reboot your computer.
Cheers!
Ryan
VISTA is instal in diff disk n it shows diff disk (when its open)
Unlike games which often require the disk to be inserted in order to be able to play them, Vista is your operating system which is, in fact, installed on your C: drive and once it is installed you no longer need the disk in your CD drive.
You can safely remove it, put it in its packaging, and save it for when you have problems that require you to re-install it.
fyi. An operating system is a collection of software that is used to control your computer hardware on one side, and allow you an interface to use it on the other side. The programs you install use the operating system in order to indirectly use the hardware to do what they do. The more popular operating systems in use today are the various flavors of Windows, and also the Mac o/s, Linux, Unix, QNX, Netware and others. They all have strengths that make them the best choice in a given situation.
Apr 28, 2009 | Microsoft Windows Vista Ultimate Edition
2 operating systems
hi mureen ok boot into windows you want, then when it's all loaded right click on the start button choose explore, then go down the list till you see the windows forlder one will say windows000 something like that, click on that one choose delete, then when it's deleted, close the box by clicking the red x at the top corner.
now once this is done we need to remove it from boot, press start then go to run...it may be under accessories ......type in msconfig then choose the BOOT.INI on the tabs.....then click on check all boot paths it should find that there is one copy of windows now and ask you if you want to remove the other one.
then click ok on the box and let it close.
now reboot your computer and see it asks you what version you want to run........
hope this helps.
Nov 01, 2008 | Computers & Internet
Windows startup error
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Feb 17, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
340 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
