Question about Kenmore Elite 45986 Front Load Washer
F11 error Iget an f11 error on my he4t
  • sinook Jan 11, 2009
    on the f11 error code, are you talking about replacing the microcomputer, or the user interface?
  • sinook May 11, 2010
    are you talking the microcomputer? or user interface?
  • 5,911 Answers
"F11" is a Serial Communications error. Before assuming you have a problem with your washer, the manufacturer recommends unplugging the appliance for at least 30 minutes to reset the computer. In many cases this is all that is required to correct momentary computer glitches. If you try this and the problem persists, the following link explains the "F11" error in more detail:
In most cases this error turns out to be a failure of the Central Control Unit (CCU). If the Motor Control Unit (MCU) fails, there is usually an additional error code that will appear. I say "usually", but not always. I hope you find this information helpful. If you require additional assistance (i.e., parts, instructions, etc.) please let me know.
Posted on Sep 12, 2008
Check all the wire connections at CCU and MCU. With the unit running and top cover off, wiggle connections to try and induce the fault. If it faults when touching the connectors at the CCU, it could be a connection issue or a bad board. In my case it was a bad CCU. Part house wanted $250 for it but found it online for $175. Took 5 minutes to install.
Posted on Oct 03, 2008
  • Troubleshooting and Repairing the F11 Error Code in a ...
    • 6 MIN
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - · PDF file Kenmore Elite He3 F11 Error Code How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error code F11
    F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
    Nov 25, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Water is in the bottom of the washer after a day
    are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
    Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Washer stops with F11 code; door won't open
    Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check the Drive system for any worn or failed components
    • Check MCU
    • Check CCU
    • Check Motor
    May 05, 2009 | Washing Machines
    Iget a f-11 trouble code on my kenmore elite he4t washer.
    REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
    Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore HE4T Elite F06 problems
    Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
    Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    He4t F0, F11 codes
    f11 is a communication error, assuming it was used in one home and now moved to another. i would remove top of unit and check wiring(especially leading to latch assy. that tub was probably banging around quite abit on the move(assuming shipping brackets werent put back in.) def chack all wiring first
    Feb 23, 2008 | Kenmore Elite HE4 Electric Dryer
    Sears kenmore elite he4t
    Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
    Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    368 people viewed this question
    Sal De
     Brian Main
    Brian Main
