Question about Whirlpool Duet GHW9150P Front Load Washer
No power...at all
This machine sucks!!!! Ive replaced the door latch assembly twice and the main control board once, and I've had the machine for 2 years.. any ideas
  • 750 Answers
Friend,
huuum At your service!
YES YOU GOT A LEMON!
WATCH MAGIC AS I TURN YOUR LEMON INTO A CHERRY!
Here is what you must do!
I do this a lot for my customers!
We are a family business for over 65 years
READY??
You get together all the service invoices and organize your self with the sales slip and service slips and call Whirlpool.
Ask customer service for a supervisor!
Then we are going to get them to do a whats called a "PUSH-PULL"!!!!!
You tell them when you bought it and how many times service has been to your rescue! With documentation of dates
Be calm, nice and reserved! BUT FIRM!
You want them to replace this lemon with a brand new machine!
WARRANTY TIME MEANS NOTHING WITH DOCUMENTATION!
THEY KNOW IT'S EASIER TO KEEP THE CUSTOMERS YOU HAVE THAN FIND NEW ONES TODAY!!!!!!
EVERY DAY GE OR SOME OTHER MANUFACTURE ASKS DEALERS TO DO A , "PUSH PULL".
THEY PAY US TO ORDER AND DELIVER AND PICK UP THE LEMON FOR RETURN TO THEM!
NO COST TO THE CUSTOMER!
Not even delivery.No matter what the dealer says to you about money! No money, honey! Got me?The companies forbid the dealers from taking any money from the push pull customer !
They pay us!!!
Unless you want to tip the guys on the truck.
Some times I've told my customer that when it's a lot past warranty that for good measure, Tell them,
"I just took a loan to remodel my whole kitchen, and I have gutted the kitchen and found all my stainless steel Ge profile appliances that I am ready to purchase BUT !
But I cannot in good faith follow through with this buy until I see that GE does indeed back up their product!
Your going to love the service and being in control!
You are fine now!
All will be right!
JUST , NO MATTER WHAT HAPPENS CALM, SMOOTH, QUIET, AND HAVE A NICE PLEASANT ATTITUDE. ANGER GETS US NOTHING! iF SOMEONE WILL NOT PLAY BALL, YOU POLITLY ASK FOR THE SUPERVISORS SUPERVISOR!
AND ASK THEM TO SPELL THEIR NAMES AND ID # TO YOU SLOWLY!! THEN WRITE THEM DOWN!
I LOVE THIS!
MY COMPLIMENTS,huuum
BLESS YOU!
PLEASE GIVE ME THE BEST RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
My web site is www.nastasisfurniture.com
We started with appliances 65 years ago and still sell them TOO!
Posted on Sep 12, 2008
Door will not lock .what do I need to replace .?
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
It can also be a defective main control board, but this is not common.
Feb 20, 2015 | LG Washing Machines
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Maytag Neptune MAH6500AWW door will not lock
#1. If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it. Part alone will cost around $110-$125.00 + S&H
#2. If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism. You do not want it to be this problem. This board is out of stock and runs over $245.00
May 30, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
I'm getting flashing error code on washer. It's flashing " DE" Thanks! Sam Singleton
If you've already tried to unplug the machine and that didn't correct the issue, the door latch assembly will need to be ordered and replaced to fix the issue. The latch assembly is just not reading that the dor is shut properly even though it is.
It doesn't matter if it appears to work or not--it's not giving the correct signal to the control board after it locks to tell the control board that the door is latched and shut and ready to start the wash cycle. This is why you need to replace the latch assembly.
Nov 07, 2011 | LG WM2301HW Front Load Washer
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Door opening mechanism does not operate
HI, check the connections that link the door lock switch mechanism to the actual control board(main). if the connections are in good condition and, the harness is not fouled, replace the door lock switch mech. it has failed.
Jul 13, 2009 | AEG Washing Machines
Door lock
The MAH5500B Neptune does not have the door latch wax motor so you won't have the R11 resistor burnt...
With that said.. Maytag made the door latch assemby one complete assembly meaning that you cannot replace the micro switches, solenoid, etc. On the older door latch assemblies Maytag broke it down to all of the little parts, ie. 12002535 wax motor, etc. I imagine that this was to reduce the part numbers folks would have to store in inventory...
You stated that the door is not locking? Did you pull on it to verify this? or could the door lock indication be not working?
There are 2 microswitches in the door latch assembly, one lights the door locked light and the second actually tells the control board that the door is locked. It is possible that the door is locked but the door locked light does not come on...
It more than likely could be three things.. The door latch assembly, wiring or control board. I would take Neptune apart so you can have access to the door latch asembly See www.neptunewaxmotor.com for step by step photos. Put a volt meter on the solenoid wires and see if you get 120VAC when the door should be locked. If so, then the solenoid coil is probably opened up and you will have the replace the door latch assembly. If 120 VAC is absent then I would check the wiring from the door latch assembly to the control board with an ohmmeter (unplug Neptune to be safe while using ohmmeter) If wire continuity is good then I would suspect the machine control board.
Jul 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
