Question about Sony KP-57WS500 57" Rear Projection Television
Screen flashes ble, then tv turns off
Screen flashes blue then tv turns off
  • Laura7hockey Sep 12, 2008
    Thank you Tim
    Is it possible for me to order a new blue tube and replace it myself? cuz $500 - 700 is not in my budget.
    Novelist:
    Champion:
  • 203 Answers
This is a common problem on that model, you have a bad blue tube, it is shorting out and the tv is shutting off to protect from furthur damage. Sony had a major problem with this it is not uncommon to have more than one tube bad. To have one tube replaced by a repairman will run you $500-$700 let me know if I can be more help?
Tim Nolan
Posted on Sep 12, 2008
  • experttv
    experttv Sep 12, 2008
    Well you might be able to I would need the model number and the serial number to get you a part number. sometimes the tubes are no longer available and in this case they have to be sent off for rebuild. If you are considering going forward with this I would like to talk to you in much more detail because its not a simple job, there is alot involved. It is something that i have seen people do before but usually with a great deal of difficulty.
    Tim nolan
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Hannspree ST42DMSB flashes blue
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 13, 2015 | Hannspree ST42DMSB 42 in. LCD TV
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
I CONNECTED MY CAMERA TO MY TV TO WATCH A SLIDE SHOW LAST NIGHT. THIS MORNING ALL I GET IS A BLE SCREEN. HOW DO I GET BACK TO TV?
Probably have the wrong "Source" selected... it's most likely still looking for the input from the camera which I assume you are no longer looking at. Blue screen is the "screen saver" mode when there is no signal.
May 30, 2011 | Mitsubishi Televison & Video
Flash blue screen
replace the power supply of your tv it is located at the back....of the monitorthere is a shorted component of your tv specially the supply of the lcd backlight.
May 17, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
TV FLASHES DIFFRENT COLOURS
The set could be in a demo mode.Wich brand is the set?
Jul 20, 2009 | Televison & Video
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
