Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
GE PROFILE S/MF400940M WASHER
WHEN WASHER IS SET TO WASH A LOAD IT WILL NOT FILL FOR THE FIRST WASH CYCLE
Change the timer
Posted on Apr 07, 2009
My ge profile wpdh8800 won't fill with water in any wash cycle. Have done all the troubleshooting suggestions, including cleaning lines and even turning off power to hopefully reboot electronics. Any...
You need to remove top cover to get to inlet valve (part where hoses attach). Be careful while testing parts for 120 volts. The inlet valve usually has 2 electric coils on it, some have 3 coils. While the machine is in fill cycle, check for 120 volts across each set of terminals on each coil (round plastic part with 2 terminals at each end). 1 coil is hot water--one is cold water (in some 3 coil valves 3rd coil is warm). If 120 volt is present depending on if machine is on hot or cold, the electronic boards and controls are good. Problem will be with the inlet valve itself and will need replaced. If no voltage, problem may be with control board or wiring.
Feb 21, 2015 | General Electric Profile WPDH8800JMG 4.2...
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Mar 19, 2014 | GE Profile WPRE6100G Top Load Washer
Faulty stop pause button on ge profile wpre8150
This is caused by a faulty control board. The button you referred to is part of the board and the control board manages all aspects of the wash cycle. You will need to replace the control board. Here is a link to the part you need.
Oct 13, 2012 | GE Profile WPRE8150K Top Load Washer
How long does it take to complete a wash cycle
In a perfectly normal washer with decent incoming water pressure it should take 3-5 minutes to fill depending on water level size selected.
If what your experiencing is that your washer does fill yet it takes forever the problem is going to be with the water inlet valve.
GENE
Oct 04, 2011 | GE Profile WPRE6100G Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Oct 27, 2008 | GE Profile WPRE6100G Top Load Washer
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Water is flowing into machine & it will not fill
If your machine wont fill, what IS happening? Is the pump coming on & not allowing the water to reach the correct level for the rinse cycle.
Oct 22, 2007 | GE Profile WPRE6100G Top Load Washer
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
77 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
