Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Water does not drain from the Freezer during the defrost cycle
Our Frigidaire frost free freezer runs fine. During the defrost cycle the heat come on and melts the ice on the coils. This water running to the bottom of the freezer but refreezes before it can drain properly. The drain hole is clear and not clogged. Each depfrost cycle more and more ice is built up in the bottom of the freezer over the drain hole. The freezer is located in a basement at 68 degrees. It is also level.
  • 4 more comments
  • Gbpfan10 Oct 01, 2008
    Thre freezer does not have a drain hose. The drain on the back of the
    freeze has a very short pipe about one inch long directly over the
    metal drain pan which is attached to the compressor. At the end of this
    short drain pipe is a cap. This cap is suppose to act like a trap. The
    cap is about the size of a silver dollar. As the water flow from the
    freeze during defrost it over flow from the cap and drips in the
    pan. The cap has a little water in it. This water acts as a seal
    so air does not excape from the freezer.
  • mojolink Apr 09, 2009
    I have the exact same freezer, with the exact same problem, the drain hole is clear except when the water freezes in it and blocks the flow. I have the freezer in the basement, where in the winter (live in Michigan)the basement temp can get to 60 - 65 F. Also this freezer is about 6-8 years old and has worked fine up til now.
  • Anonymous Mar 12, 2014
    freezer coils in our Frigidaire frost-free upright freezer are completely frozen(a solid block of ice) so when it tries to defrost, water runs out of the bottom front door of the freezer.
  • Anonymous Mar 27, 2014
    already tried letting it melt any ince in the line, no joy. how do I clear the drain line?
  • Anonymous Mar 28, 2014
    Water runs out of the water dispenser when the ice maker fill with a large volume of water. There is a growling noise inside the back of the freezer.
  • Anonymous Mar 30, 2014
    Ice accumulates by the drain area at the bottom of the freezer even if hole is clear. Eventually it spills over to the entire bottom
  • 943 Answers
Hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Posted on Sep 27, 2008
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer seems to be stuck in defrost mode
Sounds like the pat test fried the pcb. They use too high a voltage to test the appliance wiring and it doesn't do printed boards much good!
May 11, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Self defrosting / but there is ice in the bottom
The most common thing that causes this is a stopped up drain. Thaw the ice out of the bottom and locate the drain hole (probably towards the back, possibly behind the back panel) and clear with with a stiff wire or coat hanger.
If the water is unable to drain from the freezer during the defrost cycle it collects in the bottom and freezes there when the freezer is running again.
Hope this helps, let me know if you need further assistance.
Oct 06, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Jan 30, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
419 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
